I started having intermittent locking issues last fall before I stored the car for the winter. Right around that time, the passenger door lock pin disappeared. I'm guessing they are related and I need a new actuator, but is there any way to confirm that that is my issue before tearing the door apart?
Troubleshooting Door Actuator
Originally posted by sapote View PostBoth with key fob and console button?
Maybe the dirty actuator but most of the time it's the GM5 pitted relay contact needs cleaning
Thanks.
Originally posted by enjoy_m3 View Postjust fyi, GM5 Module has to be programmed to the car. Make sure your battery is at full charge capacity because it can cause issues also. bmwgm5module repair can also help2003.5 BMW E46 M3 Laguna Seca Blue / LSB
Originally posted by duperdog View Post
Neither fob nor the center console button work. I also checked fuses, no issues there. I ordered a GM5 module off eBay and will throw that in and see if that resolves it
Thanks.
piggybacking on this thread......
my drivers side door doesn't lock/unlock with the key fob, but the trunk and passenger side works. central locking button on the interior also work. based on some general E46 searching it's not the GM5 module, and it's not a problem with the key, which leaves me the lock actuator I think?
Glad you got it fixed!
I just went through a similar issue where the passenger door was double locked. Trouble-shot and replaced everything I could before ultimately sending the GM5 off to Scotty @ BMWGM5.com. Huge shoutout to Scotty and his work so if you ever have issues I'd highly recommend checking out his website!
2003_Alpine White_6MT_SlickTop_Cloth
IG: BlackForestM3
