Originally posted by Slideways
Can’t get correct camber after subframe reinforcement
+1 on the GCs, what I'm running.2003 | 3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
The alloy ones with annodized red nuts. Not the black steel. Don't get steel. Stock steel is thin and made to bend before the trailing arm, but afternarket steel arns are much thicker (and heavier).Originally posted by JokerElite View PostDidn't know SPC made the Eibach arms. Both are $200 and if it gets the job done for stock suspension on the street, I'll be ordering from FCP. Thanks all!DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
So this https://www.fcpeuro.com/products/pro...ibach-5-72110k opposed to this https://www.fcpeuro.com/products/bmw...steel-5-67110k ?Originally posted by Tbonem3 View Post
My factory arms held up 150k. Is the black steel actually weaker? Idk if the alloy ones are overkill for street use.
Not weaker, too strong.
Theyresupposed to be weaker than the rta.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
I was wondering where FCP had them for 200 cause the aluminum ones are 418.Originally posted by JokerElite View Post
Here is a set of the aluminum ones for 250 - https://www.ebay.com/itm/326187624000?_trkparms=amclksrc%3DITM%26aid%3D1110 025%26algo%3DHOMESPLICE.COMPOSITELISTINGS%26ao%3D1 %26asc%3D270393%26meid%3Df0a5af0c963745caa806026fb 9d148bf%26pid%3D101506%26rk%3D1%26rkt%3D25%26sd%3D 116057473941%26itm%3D326187624000%26pmt%3D0%26noa% 3D1%26pg%3D4481478%26algv%3DAlgoIndex5SimRanker%26 brand%3DEibach&_trksid=p4481478.c101506.m1851
