IND | Rogue Engineering E46 M3 Aluminum Lifting Block Set
    BMW TIS only shows jacking up from the front center jack pad and raising the car on a four post lift. I could not find any info on jacking up from one of the side jacking pads.
    My document in post #23 is directly from the E46 3 Series Coupe owners manual.
    As for the TIS I’ve seen both mentions of using a trolley jack at the six locations; four rail jack pads, center front and by rear diff. I’ll see if I can grab quick screen shot.
      I could not find that in the M3 specific manual. It only has the mobile tire kit instructions.
        Well that’s because the M3 doesn’t get the jack and spare standard.
        The E46 Coupe manual doesn’t have the instructions for the mobility kit if that helps answer that. Since they never got it.
        But as stated the BMW space saver tire and BMW jack instructions for M3 show to use only those four.
          I have never seen this design change. Do you happen to have info/documentation of this being a flawed different design between Coupes and Sedans/Convertibles? The only thing ever seen was it getting rusted out on some extreme cases. And the rears tend to be more prone to extreme rust.
          And BMW never posted a TSB about this afaik, and jacking flaw knowledge would be a severe safety issue. If it were a rust issue that’s another story. But a major design flaw at jacking points would need a safety bulletin no?
          I don’t think it has ever been publicly acknowledged, the cases of extreme rust originate from this though, because the jack pad tips in on the on the outside, the overlapped section on the inside opens up a bit, which allows moisture to get in and rots out the jacking point.
          This is what happens to the jacking point if you just lift one rear corner with a floor jack, the outside tips inwards, it is supposed to be parralel to the arm of the lift.
          Click image for larger version  Name:	jackpoint1.png Views:	0 Size:	843.2 KB ID:	269076
          If we cut away a part of the outer section we can see the structure within, the outside curves upwards further and is attached to the outside of the panel with 2 more spot welds.
          Click image for larger version  Name:	jackpoint2.png Views:	0 Size:	859.3 KB ID:	269077
          I have modified a 2 foot crowbar to fit in the hole on the jacking point, which allows me to pull the jacking point back straight with only the length of the crowbar as leverage, the metal is that weak, I would imagine that lifting a car is much more stressful.
          After pulling the jacking support back straight, we weld in a triangle shape to prevent it from tipping inwards again, it's not all that complicated but it's a fair amount of work.
          For the reason why this only happens to the coupe, we cut open a sedan that was going to be scrapped and we found that there's an additional support on the outside of the jacking structure (exactly the part that fails on the coupes) which goes further upwards.
          On the coupes this entire part just simply isn't there, I don't really know why.
          Click image for larger version  Name:	jackpoint3.jpg Views:	0 Size:	174.6 KB ID:	269078
            The info on the coupes being different from the sedan you cut is indeed fascinating. Thank you for sharing this info.
            The other confirms in photos as was said these rust out. Then become damaged. I’ve had over 100 E46s on lifts and have yet to come across any with damage there in SoCal. I mention region because I don’t see rusted cars. This is my caveat. I do however know these do get damaged from seeing and reading feedback worldwide and rust. This is especially true in Europe. Companies make and sell this section of metal just to replace from rust damage. At all four jack pads and not just rear. But rears are most common rusted out area. Here’s one I know about from before showing those same plates and areas. You may find it interesting.
            Four jacking point in rocker panel fits for E46 coupe, sedan, touring . You get 4 jacking points repairs kits . Front left side, front right side, rear left side, rear right side. FL + FR + RL + RR - 2 x4 - 8 parts. Parts of the sill you can find in parts
              old///MFanatic
              As I said in my first post, I believe the rust to be a result of the problem and not the cause.
              If you look at the second picture I posted you can see only the outer (super thin 0.8mm) panel was rusted a bit, which I believe happens because of the bends the metal makes the paint and sealer cracks and flakes away.
              The internal much thicker support plate was pretty much not affected by rust.
              So I am not 100% sure if we can blame this on rust, the evidence I have seen suggests not.
                Anyone try these? My RR is dented slightly; RL is fine. At home I use a Quickjack for everything and it lifts fine, but want something more stout to use at the track to swap wheels (my Daytona jack isn't long enough to use the diff/front center point, and I'm not lugging a 100 lb+ extended reach jack). Are the front corner points strong enough to lift an entire side without denting?
                  I have the RE blocks, been using them (too much) for about 6 months. Not much to say other than they work and haven't given me any trouble. My jack stands are the HF knockoffs of Esco and pair well with them. Wouldn't want to use the jaw style stands.
                  Can't comment on the OE front corner points personally, but from what I've read those don't seem to have the same weakness that the rear may develop.
