IND | Rogue Engineering E46 M3 Aluminum Lifting Block Set
  • old///MFanatic
    Originally posted by LeeForst View Post
    I thought it was ok to quickly lift from one rear point in a pinch for a flat
    It is. The other E46s come with a factory jack that actually is made just for using any of the four factory jack pad locations.
    The BMW accessory “Emergency Spacesaver Spare & Jack” kit come with similar jack and same use instructions.
    Click image for larger version  Name:	IMG_0289.jpg Views:	0 Size:	83.2 KB ID:	268234
  • SQ13
    do you drive up boards or ramps to get enough height for a jack to get to the hockey puck?
    I use a race jack on the front right or left jack pad to get the tire 1-2” off the ground, then I’ll use a low profile jack to lift from the center puck. Boards or ramps work too.
  • Black107
    do you drive up boards or ramps to get enough height for a jack to get to the hockey puck? what's the difference between lifting the car by the jack blocks and resting the car on the jack blocks+jack stands?
    Yes I put the front up slightly on ramps to get to the hockey puck when I want to put the front on stands.
  • LeeForst
  • tnord
  • Tbonem3
    I never lift the car by the jack blocks. Rear subframe and front "hockey puck" on the reinforcement plate.
  • Black107
    Is the rear jackpoint issue primarily when you try to jack the car up from one of them (meaning ~half the car's weight is on it)? I almost always jack from the rear subframe so both rears come up off the ground equally then use the factory rear jackpoints for my jack stands (so only a ~quarter of the car's weight is on each point).
  • Obioban
    Originally posted by old///MFanatic View Post
    This appears to be only for the Rear. No front use.
    The front jack pads are fine to use with a jack, so no need.
  • old///MFanatic
    Originally posted by jpy1980 View Post
    Is this only for the front or is there a rear brace in the rear that you can attach this to?
  • George Hill
    I think that cutout is a non issue, I've lifted vehicles straight off that bolt before in a pinch, this solution can only be better than that.
    Clever idea, but part of me feels like its a solution looking for a problem.
  • Obioban
    Yeah but now the specially made dedicated jacking point is missing like 50% of its surface and has a weird shape that won't nicely fit a floor jack, bottle jack, jack stand, etc?
    I guess we’d have to get one in person to see, but I’d envision a jack cup fits around it and by sitting prouder than the v brace, creates an edge so the jack doesn’t slip off when raising/lowering.
  • cobra
    The cutout is for the v brace, no?
  • Obioban
    Would have been nice to not have the giant cutout in it and be more of a flat or at least uniform surface?
  • cobra
  • F1Dryvr
    The metal on my jack point/jack stand points is tearing through in some areas. Pretty nerve racking although i put backup stands wheels or a jack on all four corners. Def would like to see a solution for all 4 corners to reinforce or repair those areas.
