Would there be an issue with spacing out a structural brace like this? I'm guessing that it is better the have the brace bolted directly to the chassis.
Also, how would you position a set of quickjack to lift at that V-brace point? The QJs would be at a slight angle.
IND | Rogue Engineering E46 M3 Aluminum Lifting Block Set
My pads are pretty chewed up from the PO, was planning on replacing them with OEM. What a great idea from Rogue, will most likely get their V-Brace as well in anticipation of undercarriage cleaning/dry icing.
Originally posted by jpy1980 View PostIs this only for the front or is there a rear brace in the rear that you can attach this to?
I moved this to the e46 main section, because it is new/novel and addresses an e46 chassis weak point.
Nice idea!
On the BMW E46 chassis, the plastic “jack pad” is a common weak point. Issues associated with them include:- Factory jackpad often gets damaged, destroyed or just falls off and gets lost.
- Attachment point for the chassis gets ‘pushed in’, requiring additional support like a hockey puck when using a floor jack. With additional spacers, the side skirt can get damaged from the lift post arm/floor jack.
For E46 M3 owners, we have come up with a simple, durable, solution for the rear of the car. Our specially designed lifting blocks between a stronger, alternative chassis point and the factory V-brace attachment. Instead of a plastic pad, these blocks are CNC’d from 6061 aluminum and anodized for durability. Instead of being installed in the weak, vulnerable spot on the chassis that is easily damaged, we now take advantage of a point on the lower part of the body that has a boxed support.
The lifting blocks extend down 1” from the body, equally the previous position of the OEM jack pad and installation is possible while the car is on the ground using a simple 16mm socket and ratchet.
Sold only as a pair. Available in anodized black (for an OEM look) or anodized red (for easier visibility).
The Rogue Engineering E46 M3 Aluminum Lifting Block Set may be viewed at the following link to our online store:
On the BMW E46 chassis, the plastic “jack pad” is a common weak point. Issues associated with them include: Factory jackpad often gets damaged, destroyed or just falls off and gets lost. Attachment point for the chassis gets ‘pushed in’, requiring additional support like a hockey puck when using a floor jack. With additional spacers, the side skirt can get damaged from the lift post arm/floor jack. For E46 M3 owners, we have come up with a simple, durable, solution for the rear of the car. Our specially designed lifting blocks between a stronger, alternative chassis point and the factory V-brace attachment. Instead of a plastic pad, these blocks are CNC’d from 6061 aluminum and anodized for durability. Instead of being installed in the weak, vulnerable spot on the chassis that is easily damaged, we now take advantage of a point on the lower part of the body that has a boxed support. The lifting blocks extend down 1” from the body, equally the previous position of the OEM jack pad and installation is possible while the car is on the ground using a simple 16mm socket and ratchet. Sold only as a pair. Available in anodized black (for an OEM look) or anodized red (for easier visibility).
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | info@ind-distribution.com
Tags: None
