Originally posted by bigjae46
Rear main seal DIY
Now these are the droids I was looking for. Hope it doesn't come in handy anytime soon, but with how much time I wasted trying to get on those damn bolts I would definitely do this next time around.
If you have the engine bar holding up the engine, you can partially undo the front subframe bolts and lower the engine a little bit which makes getting to the bellhousing to block bolts so much easier. I think it is worth the extra work. Unfortunately, I've had quite a bit of practice.Originally posted by dukeofchen View Post
Yes that will suffice for engine support, for the transmission jack you'll want one that's as low as possible given the limited clearance on jack stands. I know HF makes one too so you can compare the height on that unit vs the pictured one. Get the car jacked as high as the stands can safely go because you'll want every inch of clearance possible.
As for steps the FCP video posted above is what I used to perform the whole job, my first time doing just about all of it. Not sure exactly where SMG specific steps come in as I did it on an MT.
Other tips would be to remove the fan/fan shroud, so you can let the transmission sag down as much as possible without worrying about contact up front. Laying on the ground you're going in almost blind going for the bolts securing the top of the transmission, so every bit of visibility helps.
For those bolts also crucial to have a bunch of extensions / wobbles / swivels that you can chain together to get the socket on the bolt. I'd say those bolts and mating the transmission back up are the hardest part on jack stands.
It's a hell of a job to do this way but just be patient and give yourself time.
Sorry all didn’t bother to come back here to update this. I was able to install the part just fine. I ended up going to my local Foreign body shop and paid at mechanic $20 to use the tool. He had to press the seal in.
If I was just replacing a rear main seal the only thing I would for sure replace is the pivot pin.Originally posted by BL92 View PostWhat are thoughts on part list
I need a spring and ball pin along with the seal
Need exhaust gaskets and bolts
i wonder if i can get away with reusing the release bearing? i am not sure if a new release bearing and an old clutch are compatible
But if the clutch had a decent amount of miles on it I would consider replacing it. When I replace a clutch kit I always replace the fork and guide tube as well.
LuK clutch kits are cheap enough that if you are going to replace the TOB I would just replace the kit since it comes with a TOB anyways.
Inspect the pilot bearing, generally they can reused in a RMS replacement, but I replace them with clutches no matter what.
I always replace the exhaust to header nuts and bolts if they are rusty, gaskets usually can be reused if they've been replaced recently but if original I would plan on replacing them.
*Personally if I had the trans out, I would replace the pilot bearing, clutch kit, guide tube, fork and pivot pin. Inspect the flywheel and input shaft seal and replace as necessary.
Exhaust bolts would depend on condition, I've reused mine plenty of times but I don't live in an area where underside corrosion is a concern. Exhaust gaskets from the headers to section 1 you will want to replace as they are crush gaskets.Originally posted by BL92 View PostThanks for that
This jack is a lot lower to clear
I have Quickjacks to be able to get more height over the jack stands, its just Quickjacks have no side access
Don't personally have an opinion on the throwout bearing and pivot fork, certainly wouldn't hurt to replace as they are wear items but depends on condition / age.
One easy part I would absolutely replace if it hasn't been done is the pivot pin (#6 in this diagram), they become brittle with age and if it snaps you'll be pulling the transmission again as it's integral to the clutch release mechanism. New OE plastic, steel, and brass replacements are among your options there - I went with this one. Also re-lube the appropriate contact points with the appropriate moly grease when putting back together. While you're in there would also be a good time to refresh all the shifter bushings if you haven't yet, it's a PITA with the transmission installed.
Thanks for that
i wonder if i can get away with reusing the release bearing? i am not sure if a new release bearing and an old clutch are compatibleLast edited by BL92; 12-08-2024, 02:47 AM.
Yes that will suffice for engine support, for the transmission jack you'll want one that's as low as possible given the limited clearance on jack stands. I know HF makes one too so you can compare the height on that unit vs the pictured one. Get the car jacked as high as the stands can safely go because you'll want every inch of clearance possible.Originally posted by BL92 View Post
Now I am thinking about whether or not to use the new style seal (sans spring) R.M.S on my S85, doing a flywheel and it's right there and leaking slightly.Originally posted by bmwfnatic View PostI don't like these 'new style' seals that BMW has switched to, also retroactively for older cars it seems.
Over time the front and rear main seals create a low spot on the crankshaft, you can feel this spot with your finger, it's quite pronounced.
If you install one of those new style tensionless seals, and your low spot it quite large, they will never seal, they leak.
I prefer to stick to the 'old style' seals with a spring inside them, they provide more tension and are more forgiving if the crank surface they are riding on isn't absolutely brand new.
A generic 110x90x12mm seal with the right properties and a spring is suprisingly easy to source.
I did notice that the seal does not have a spring, not wanting to fuck around with a seal that may leak. Don't know if there are any alternatives to the the new seal.
Also have to deal with the bed plate parting lines, you have to buy a special tool for a syringe, and use two different compounds to do it "right", almost like an epoxy type substance. I used Toyota FIPG on the front main seal bed plate parting lines and no leak so far, and I do believe the new seal did have a spring.
I would remove driveshaft before lowering the transmission.Originally posted by BL92 View PostRemove propeller shaftLower transmission until cylinder head touches firewall.
Support engine at front.
remove starter too.
i think the engine rests on the subframe before the head touches the firewall.
yes, use floor jack to push the engine front up when removing the transmission, else it will fight you and then tip over when tranny if off.
Could we get some info on your processes of the removal of the box? i gotta pull mine to replace the input shaft seal
So far i found these steps for SMG in ISTA
Necessary preliminary tasks: - Disconnect battery, battery positive lead from battery terminal.
- Remove intake air manifold.
- Remove heater bulkhead.
- Remove fan with fan impeller.
- Remove engine splash guard.
- Remove reinforcement plate..
- Remove exhaust catalytic converter and intermediate pipes.
Depressurize hydraulic system
Remove heat shield Disconnect plug for transmission oil temperature sensor (1) and transmission speed sensor (2). Disconnect plug for reversing light switch (1). Unclip hydraulic lines at holders Release nuts and remove clutch slave cylinder (3).
Pressure pipe remains connected.
Slowly relieve tension on clutch slave cylinder (3) when removing otherwise air will be drawn in through sealing sleeve.Remove propeller shaftRelease screws and remove cross-member (1).
Support engine at front.Lever out retaining ring (1) with a screwdriver. Drive out retaining pin (1) on selector rod linkage with special tool Release screws on actuator Unfasten screws and Pull out transmission as far as possible towards rear, turn approx. 10° in counterclockwise direction and remove.
Any update on this RMS? Did the kit from BMW Parts Factory manage to fit?Originally posted by Maxhouse97 View PostPart still not here from BMW parts factory (haven’t dealt with them before) and I made good progress last night, almost have the trans off. If I got into a pinch, could I install the seal I have without the factory tool? I saw guys on youtube using a block of wood…
