Help Deciphering Codes
    Hooked up the Foxwell 510 and got a lot back. Wondering if anyone can help me decipher and prioritize. First listing is main fault, then detail after reading.
    Base module 5 ZKE (GM drive rear lid unlock)
    Auto Heat Air IHKA (AUC heating)
    Instrument cluster KOMBI (Data filing difference central light module)
    Multi Restraint System ZAE (MRS power supply)
    Telematic Control Unit (TCU microphone open circuit)
    Light Switch (2 faults, LSZ2 coils, stepping motor AND LSZ2, control unit fault HVAC system)
    There is nothing currently inoperable on the car that I notice. TIA.
    Interlagos 06 M3, Autologic tune, Agency Power midpipes/exhaust, Fortune Auto coilovers, UUC SSK, Bluebus, Lightwerkz retrofit. MRegistry listing here
    Clear and see what comes back.
      After you do the autoscan and it lists all modules, those that have faults will display counts on the right. You have to go into "display DTC" option. List the actual DTC (the alphanumeric codes), they are usually 4 characters in length.
      Youtube DIYs and more
        AUC one is the air quality sensor heater for the auto recirculate. They always fail.
        LSZ MRS ZKE and KOMBI would probably be the more critical.
        What doesnt work or are you just trying to clear every code to be neat?
          I wouldn't worry about a single one of those faults unless you are chasing something specific.
          Almost every E46 I see has some variation of those faults stored at least a few times.
          As noted above, clear them and don't worry about it.
