Rear Sway Endlink Bracket Torque
    Hello,
    I finished a rear outer suspension refresh (Monoball RTAB, Upper & Lower Outer Ball Joints, Spring Pads).
    I now am getting a single pop noise when accelerating hard. My plan is to go back and make sure everything I touched is tight.
    I have torque figures for everything except for #10 in the link below (bolt that attaches the endlink to the bracket)
    RealOEM.com - Online BMW Parts Catalog
    Does anyone know what this value is?
    I found an ECS DIY that lists Rear Sway Bar Bracket Nuts as 25 Ft-Lbs, but I believe that is #9 in the RealOEM diagram
    PDF_11107_BMW_E46_Sway_Bar_Installation.pdf (rackcdn.com)​​
    22 nm as per TIS, for pretty much everything in that area, torque spec PDF also lists that.
      Thank you!
      Just found the PDF - what an incredible document!
