Front Control Arm Ball Joint Boot Repair
I assume your ball joint still have good resistance like a new ball joint? FYI, I believe z4m control arm part number is the same as zhp. Lemforder makes an HD version with replaceable ball joints. Too bad the e46 m3 doesn't have a version.
Originally posted by davidinnyc View PostThis thread couldn’t have come at a more perfect time. I decided to swap back to stock suspension on the vert and absolutely obliterated the boot on the driver’s side… ordered parts!
Originally posted by 4getr34 View Post
Job done!!!
to answer the questions above… when installed the blue ring does not have gap (before removing), i actually think I bent it a bit during the removal process. The same happened to the original ring which was yellow. That was one of the reasons I replaced it. You have to spread it open some!
the McMaster part is
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
ones installed both rings were perfectly circular
Originally posted by maupineda View PostThe ring came in. Exactly the same size but much easier to install.
I like the key ring style ring better as it creates a complete uniform 360 deg pressure for a good seal.Last edited by sapote; 07-13-2024, 10:20 AM.
Originally posted by maupineda View PostReceived the donor ball joint and removed the boot.
The larger bottom ring is required to keep the boot from popping out, and the top ring is only to keep the water and dust out, so I think looping a copper wire 2 turns and twist the ends will work as an easy substitute.
The blue rings are the originals. the larger ring is called a retainer ring, and is like the ring of a key chain, the smaller ring is more of a snap ring that is pretty tough. I used a shallow pick to just get it behind the ring and pry it out carefully. I chose not to install this smaller ring as I am sure I would end up punching a hole on the new boot trying to install that thing on. instead I got another retainer ring from McMaster, it is basically identical to the larger one but smaller, and lucky me McMaster happened to have one of identical diameter.
You can see below the retainers. And the tools I used. The zip ties are to pull the ring apart to wind it on and not damage the boot. When I receive the small ring tomorrow from McMaster will share the photo
I trailed installing the torn boot onto the new ball joint to learn the process. The ring retainer that looks like a key chain ring is easy to install, just wind/unwind it around with the help of pick. You can also fish in a zip tie to spread the ring apart and start unwinding out.
Nice. Also can you share some of the videos you watched? I need to do this.
Is that an E36 strut? *Edit, I saw your other post, its a Z4.
Either way I feel your pain, but seeing that blue M/// tag makes me think this arm is original and at 20yrs old +/- its probably a bit tired anyways. If that ball joint moves freely even with out any discernable play I'd consider replacing it while you are in there.Last edited by George Hill; 07-08-2024, 03:50 AM.
When I replaced the ball joints on my tacoma, the new ones came with a little roll of safety wire and they instructed you to give it 2 wraps and tuck in the twisted end where it won't be at a pinch/bend point. Seems to hold up alright.
I searched up and down without anything specific to our suspension architecture relative to a dust boot repair/replace on the front control arms.
While removing the front knuckles to refurb them I damaged the boot on the passenger side, I was very reluctant to spend 300 on a control arm just for a stupid rubber boot. So I came up with the idea of sourcing just the ball joint, which is available for non M control arms from Lemforder to harvest the boot.
bloddy hell, those rings are a PITA to remove, but is doable after watching some YT videos on how to remove these boots on some Japanese models.
the image below shows the naked ball joint.
I will post photos of the boot and clips that hold them in place.
