First DTC scan
    First DTC scan
    Just bought an Ancel scanner and hooked it up to my M3 (report attached). Nothing too bad/surprising, am hoping driving the car a bit will help clear some of these. Anyone have experience with them?
    The scanner does show error codes it cannot decipher, I would recommend that you pick up an older windows laptop and use BMW Scanner and INPA for scanning for codes. Its the most common scanning software for the E46 and will scan specific BMW codes.
    You will also need 2 ODB cables which are relatively cheap. BMW Scanner and INPA use different types of ODB cables.
    These 2 guides on E46fanatics are great to get it setup.
    BMW Scanner 1.4 (PA Soft)
    This thread is intended to contain all information and links for BMW Scanner 1.4. Background BMW Scanner 1.4 runs on Windows, and provides the ability to read/clear trouble codes, view live data, code settings, and test functionionality on most control modules found on BMW models produced from...
    INPA
    This thread describes how I install and configure BMW Standard Tools, the suite of BMW software that includes INPA, NCS Expert, WinKFP, Tool32. I have my own custom way of doing this that is the shortest and simplest steps I could figure out. This set up is for E46 only. What is included...
