Alpha N 93 Octane Tune with 91 in Tank
    Hi everyone. Bought an M3 with a turner csl airbox and an active auto alpha n 91 tune since the car is in Cali. The PO has flashed it to a 93 tune since the car is coming back to the east coast. It has about half a tank of 91 still in it. Am I safe to dilute the current 91 with 93 and drive with the 93 tune?
    996TT
    Turbo E36 M3
    FZJ80
    Originally posted by Deen HK View Post
    Hi everyone. Bought an M3 with a tuner csl airbox and an active auto alpha n 91 tune since the car is in Cali. The PO has flashed it to a 93 tune since the car is coming back to the east coast. It has about half a tank of 91 still in it. Am I safe to dilute the current 91 with 93 and drive with the 93 tune?
    Buy some octane booster at a parts store to be safe.
    Instagram: @logicalconclusion
      What he said ^
      2005 BMW ///M3
      Black6MT Daily
        It would be fine if they didn’t turn the knock sensors way down and go crazy with ignition timing like many aftermarket tunes do. Octane booster to be safe as other posters have recommended. I think it’d be fine either way unless the tune is otherwise unusable and unsafe.
          Thanks all
          996TT
          Turbo E36 M3
          FZJ80
            I was going to mention this. It depends on the tune. If a reputable tuner tuned the car they should have built in some form of safety parameters for these types of situations.
            As others also mentioned, you could pick up octane boost to be safe.
            Also drive the car normally, and don't drive aggressively until you can get the right gas or get it retuned for 91.
              Update: filled the other half with 93 and put some octane booster in it. Every now and then the car will go into limp mode and won’t rev past 3k. Assuming it’s the lesser octane gas flowing through? It’ll go out of limp mode and be fine after, driving it conservatively until I’m sure all the gas is fresh 93
              996TT
              Turbo E36 M3
              FZJ80
                You might want to scan it for codes; otherwise, you'll have to have someone look at that tune. Octane should not throw it into limp mode.
                  No EML light or codes on my scanner. Will buy a cheap windows laptop and scan with INPA
                  996TT
                  Turbo E36 M3
                  FZJ80
