Does anybody know where to measure to get the correct backlash between the lsd spider gear? I recently purchased a used diff to rebuild since mine has been clunking for a long time now. (Had the car in the air and spun the wheels to confirm diff is the problem) I plan on measuring the shim instead of using the racingdiffs fix. I am assuming you are looking at the backlash between the spider side gears and place the dial indicator on the spider gear tooth but want to confirm. Thanks
By the way what happened to M3forum?
