Good Day. I've searched and searched. Been trying to fix this for a couple weeks actually.
If this is in the wrong section, please move it or tell me where to put it (lol).
Motor is a 2006 S54. Car is a 1998 318ti. I know, not an e46 but the motor thinks it is. I used the e46 radiator, sensors, DME, etc. I am asking here as this site is so knowledgeable on the inner workings of the DME.
The question. I had to reset the DME for various parameters because of the swap. Is there any chance I turned off the auxiliary fan somehow? If so, where do I start, fresh bin dump from github? Full or partial? Or is it time for a new DME?
A long diatribe on what I have done to date.
This stated with my aux fan not kicking in. Read the e46 fan guide (thanks), tried all the trouble shooting to include leaving the sensor unplugged. No fan. Tried to control the Aux fan in INPA. No worky. Looked in INPA, and the coolant exit reads -48.
Figured I need to fix this first. Bought a new Hella sensor for the lower radiator. Same, no reading. Checked the new and original sensors with ice / hot water and they both responded with readings of 500 - 1800 ohms. Checked the wires for continuity from sensor to the DME and got .9 ohms from both with no shorts to the other or to ground. I plugged the sensor back in and checked the readings at the DME side wires. Pins 38 &39. It seems to have ohm'd out fine. 70*f it was just over 1000 ohms. I was wiggling all ends of the wires with the meter connected. It did not change, so I am pretty sure there is no shorts on any of the wires. put it all back together, and I am getting 5v from the DME pin 39. This also seems fine.
I also checked the aux fan connection and get 12v between the 2 thick wires. Read it is hard to read the PWM wire without a scope.
Now you're all caught up.
