CF doors by Carbon Microsystem
  • Carbon Microsystem
    I'll add more photos of our doors.
    Click image for larger version  Name:	IMG-20241127-WA0146.jpg Views:	138 Size:	121.9 KB ID:	285513
    Click image for larger version  Name:	IMG-20241127-WA0147.jpg Views:	140 Size:	164.6 KB ID:	285514
  • bigjae46
    apologies for the lack of updates as i formulate a plan on getting these doors DIY installed. aiming to clear some time in the next couple of weeks to get started on this project.
    I snugged the hinges to the door so the hinges won’t move without some force. So you can put the door on the hinges and move it around. Once it is lined up carefully lift the door out and slowly tighten the nuts.
    Definitely an amateur at this so there is probably a better way.
  • usdmej
    in the meantime, i was able to remove the logo from the side of the doors. the instructions provided by Carbon Microsystem worked as exactly as described
    they recommend sanding with 240 grit to remove the label. i had 220 grit laying around so carefully sanded by hand. moderate to hard pressure was enough to get the label off and while not damaging the carbon underneath
    one small hurdle cleared! cleaning, sanding, and cleaning the entire inner door skin should be adequate to ready it for clearcoat
  • Projecte46m3
    I would be interested as well if there is a potential weight savings over the stock hood.
  • 9kracing
    Yes, if it can be used with OEM latches and doesn't require hood pins, I'll take one.
    Does anyone make a high quality OEM style hood in carbon fiber for our cars?
    I wasn't able to find one.
    If there is interest and three or more customers will come together for a carbon fiber hood for the e46, then we can do it.
    The hood will be completely carbon with reinforcement of all important places so that it can be used with the original fasteners and hood lock.
    Here is an example of the hood that we make for the e92.​
  • 9kracing
    It’s in the plan for next year
    Awww yeah.
    I think Slon makes one, but they refused to ship to the US.
  • bigjae46
    AJ Hartmann but it requires pins since its not a full 2 sided hood.
    It's not that big of a weight saver over stock unless you're willing to put up with some fluttering at speed.
  • Gt4
  • Projecte46m3
    Try reaching out to these guys... https://carbon-production.com/
  • 9kracing
  • DrM3
    very cool, thanks for sharing! can't wait to see the photos once installed!
  • Obioban
    The wants are real.
    Matte doors for E46 for our friend from Spain.​
    8,040 Followers, 2,010 Following, 394 Posts - See Instagram photos and videos from @greentrackm3
    This is what a carbon door looks like before final gluing.
