S54 BMW Cam Timing Tool vs aftermarket
    I’m interested of measuring the pin to beam angle of the EX and IN sides, as I don’t own the tool and only use a caliper and drill bit for the job.
    How many engines have you timed like this?
      Just my car.
        Actually aftermarket tool has 2 pins, if you use it- there are very little possibility to misinstall cams like on the video with exhaust side.
          I don’t understand the advantages of having 2 pins vs 1 here.
            It is impossible for aftermarket timing tools to be so misaligned that the bridge sits in place and touches two points on the cylinder head, while both pins insert smoothly into the camshafts, and the plane is still aligned. The tool would have to be extremely off and visibly crooked to the naked eye
              I see, but this hasn't happened yet for the aftermarket tools.
                Originally posted by Savageblunder View Post
                I would measure it, but not sure how to accurately do it to get a measurement more precise than the obvious 90°
                I would do this: find a drill bit or a rod that fits in the bride holes snug (the supplied pins are too short), and have 3” or more of the bit above the hole (longer is better for accuracy). Then have a 90* steel carpenter tool aligned to the bridge beam and touches the drill bit base. There is a divergent angle formed by the drill and the carpenter tool if the drilled holes are not true to 90*. Use a caliper to measure the gap at the highest position of the drill bit and measure the height at this position also. With the gap and the height we can calculate the angle.
                  Tried to do this, but could find nothing I had in hand that fit snug enough & that was long enough to do this. I’m going to say if you’ve done this multiple times not using the special tool & have had no CEL after you’ve got it figured out. I don’t put any value on vanos adaptations & have no idea what mine are.
                    Yeah, I measured this way on the stock VANOS timing before removing the hubs and re-drilled the disk smaller holes. This method works for me when I needed to remove the chain sprockets multiple times.
                    Just curios of the cam timing holes angles -- true 90* or not.
                      I think it would make the most sense if they are, going to measure this for the sake of science later. I have a genuine BMW bridge.
                        Update on this, got my cam tool back.
                        Just let me be clear I used some primitive methods for measuring this, I unfortunately do not have insanely accurate measuring equipment, so it would be nice if some others could chime in so we can get a consensus not just based on only my tool and measurements.
                        But from what I can see, it is definitely NOT true 90. It seems to be off by 1 degree towards the exhaust side, for both cams.
                        Thinking about this, it makes sense, otherwise why would the tool be labeled “A” and “E”, if it were true 90, this wouldn’t matter.
                          “off by 1 degree towards the exhaust side”
                          You meant the cams would be more retarded compared to if the pin is a perfect 90 degrees?
                          Do you have a carpenter square, and a rod or drill bit that fit snug in the cam holes?
                          Please do this:
                            Please do this:
                            Yes, standing in front of the engine the pins are in essence like this / / (exaggerated of course)
                            Your method of measurement is pretty much the same as what I did, basic pythagorean theorem to solve for the angle.
                            Even if you just remove the engine from the equation, and insert the pin into the bridge, you can tell with the naked eye it’s not at 90. Simply holding the carpenter square on the bottom of the bridge propped up against the base of the pin coming out of the hole also reveals the angle.
                              // forward slash and not backward slash?
                              So both cams are advanced compared to if the pin is standing 90 degrees?
                                I’ve spent a lot of time thinking about why BMW would do this. With modern CAD/CAM software, it would have been incredibly easy for a designer to project a perfect vertical line down from the cylinder head surface, intersect it with the camshaft at TDC, and program the CNC machines to drill a true 90-degree hole. It would have made manufacturing the camshafts and the service tools much simpler.
                                So why did they leave it "crooked"?
                                I think we often give German engineers too much credit for "master planning" every millimeter from day one. Instead of a clean math formula, the non-90-degree angle is likely the result of real-world prototype development and iterative dyno testing.
                                Here is the likely timeline of how the S54 timing setup actually happened:
                                1. The Prototype Phase: During early development, the engineers probably drilled a rough reference hole into the cam blanks just to give the dyno technicians a starting baseline to lock the engine on the stand. It didn't need to be perfect; it just needed to hold the cams close to vertical.
                                2. Trial-and-Error Optimization: As they spent months fine-tuning the S54 for maximum power, emission targets, and idle quality, they actively adjusted the intake and exhaust cam timing. They advanced and retarded the cams by fractions of a degree until they found the absolute "sweet spot" for production.
                                3. The Final "Lock-In": Once that perfect timing was found on the dyno, that physical position was locked in for production. Because this final resting position was found through empirical testing rather than a clean initial computer simulation, the original reference holes just happened to land slightly off from a true 90-degree angle relative to the head deck surface when the crank is at TDC.
                                4. Tooling as an Afterthought: By the time the engine was finalized, changing the casting or drilling programs to relocate the holes on the camshaft assembly line would have been expensive and introduced unnecessary variables. So, the production team simply took the engine as it sat, measured the resulting asymmetrical angles of the holes, and told the tool department to machine the factory service bridge (Tool 11 9 140) with slightly angled pins to match.
