SMG to 6MT Conversion
  • rcarson25
    okay I was reading this wrong. I thought you had to pin the SMG ecu with pin 2 from clutch switch. This all makes sense now. Pin 2 goes to a wire on SMG
    ECU pin that goes to a sensor. The SMG ECU ground pin goes to an empty slot on the main ECM. This all makes sense to me now.
    Also where are people getting the pins needed for the DME and ECW, which ones are they, just stealing them from other connectors?
  • ATB88
    Originally posted by rcarson25 View Post
    I am at this part as well. The only thing I am confused about here is doesn’t the SMG ECU get removed at the end? Based on the instructions it seems pin 2 from the clutch switch goes to the SMG ECU and then the SMG ECU gets connected to the main DME. I know this is only for cruise control but shouldn’t there be a method that just takes pin2 of the clutch switch directly to the DME so the SMG ECU can be deleted. Has anyone done the conversion, ditched the SMG ECU and retained cruise control?
    One other question does anyone know which female pins are needed? There are about a million different options for different connectors and I want to be sure to get the right ones.
    This was confusing to me too -- the SMG ECU does get removed, BUT wires in the SMG ECU's connectors are also connected to wires that route to the main ECU and various sensors. So, pin 2 from the clutch switch indeed goes to whatever wire the DIY says, which routes into that SMG ECU connector, but the SMG ECU must be removed for everything to work properly. When I did this I left the SMG ECU in the car and the connector attached to it, because I figured that the SMG ECU must at least be there for the signals to get where they're going -- not the case, and leaving the SMG ECU connected will actually cause issues. Follow the instructions as written, connect the mentioned wires to the SMG ECU's connector, but remove the SMG ECU itself from the car
  • rcarson25
    Originally posted by wsybert View Post
    Perfect timing on this question... this is where I am on mine as well. Subscribed!
  • wsybert
    Originally posted by TPE View Post
    For those who have done the wiring as mentioned in the original post (with gear position switch connected), it says, "Next connect the ground connector from the SMG ECU to the DME pin 20 at connector x60002 (24 pin black connector) next to the 9 pin power connector on the engine DME. Note that pin 20 on the DME is blank, and you will need to disassemble it and insert the wire with a female pin that will click into place."
    Is the original poster referring to the brown ground connector wires, circled in green, this photo:
    So I am suppose to connect any brown wire, circled in green, to the blue pin 20 wire at x60002 circled in green?
    Thanks in advance!
  • S3diment
    Anyone in/around OH/KY/IN/PA/MI that wants to help me with this? Willing to travel farther too!
  • mikeetastic
    subbed! Very detailed DIY.. thanks to the creator..
  • TPE
Name:	clutch pin 2 to dme wiring connectors.JPG
    Thanks in advance!
  • ejendow
    Originally posted by hemi6 View Post
    Without a car lift this would be a nightmare.
    just did it w/o a lift, really not that bad
  • hemi6
  • Pnick
    Originally posted by Pace View Post
    Does anyone here know why the OP used this method for wiring the pin 2 clutch switch(to pin 13 wire on SMG ECU, then ground wire from SMG ECU to pin 20 on x60002)? Other DIY guides wire pin 2 directly to pin 20 on x60002 - hoping to find the reason why and possibly a solution to my cruise control not working 🤔
    He had a quote a few steps down...
    "*Note that it is NOT necessary to do anything with pin 2 on the clutch switch in order to get the car to run. This connection is purely for the function of the cruise control in conjunction with the gear recognition sensor that was installed in the tapped M14 hole in the transmission. Also note that even wired correctly, your cruise control will NOT function until the car has been recoded with the proper 6MT tune."
  • ejendow
    Originally posted by Ob917 View Post
    I used the same shifter and rod. I don't seem to have any slop in any gears. I'd guess it's not an adjustment but something that's worn.
    Does yours center between 1st and 2nd or 3rd and 4th?
    I adjusted it so it centers between 3rd and 4th and its not a slop problem I'm having. It's just that when the car is driving and I'm shifting from 1st to 2nd, I get a loud clunk sound coming from the tranny area. It's strange, doesn't happen in any other gears and doesn't happen when the car is off. Can't be the guibo either since I just replaced that.
  • Ob917
    Originally posted by ejendow View Post
    I just finished the swap yesterday and used an RTD shifter w/ a DSSR. I get a pretty loud metallic sound coming from the transmission/linkage area when shifting into second gear. Does anyone know what this sound might be caused by? No other gears make this loud of a sound when shifting into.
  • ATB88
    Originally posted by SandeepM3 View Post
    Could what he did at 14.55 in the video be the solution to shifter slop? Sounds promising and that thing did look solid.
    Oh cool. I actually did this when I did my swap because I just could not get the manual pin into the hole. It seemed like my SMG bolt had, in the past, been tightened a little too hard and the aluminum hold had warped every so slightly such that getting he manual pin into the hole was now totally impossible. So I just re-used the SMG bolt. I honestly see no reason why they don't just use the SMG bolt on the manuals to begin with, that pin thing sucks.
    Also, cheesy nostalgia: Man, every time I see this thread bump back up to the top I'm reminded of how much of an adventure this swap was. Was my second time really working on a car (first was a clutch job on a MK1 Audi TT), and I've learned a ton since then. Can't believe it's been 2 years!
  • heinzboehmer
    I've been chasing a sloppy shifter ever since I got my car. Replaced all bushings multiple times. Latest thing I've done is replace all detent springs in the transmission and upgrade to an AutoSolutions autocross SSK. There was no slop between the transmission and shifter carrier even with the regular pin. There's still about 10mm of side to side play in my shifter.
    I've basically given up now and am pretty certain that all the slop that's left is internal to the transmission. Looking at pictures of the bellhousing, there seem to be gaps between the detent bearing and the detent pins, which is potentially the source of the slop. At this point I'm just planning on swapping in an E92 335 transmission whenever I've run out of other things to do.
    (Rant over) I you've got slop in that connection though, the SMG bolt thing might be worth doing. It'll also get rid of that stupid pin lol.
  • SandeepM3
    Originally posted by Distinct View Post
    I'm a subscriber to this channel on youtube and they released a detailed and well filmed/hosted video on their SMG to 6MT conversion. I really like these guys and I thought the video is great.
    This is part 1: https://www.youtube.com/watch?v=wDThhOoVGIc
