Ground control race camber plate question
    Most certainly not. As installed, he can only loosen the 3 nuts and get caster adjustment (but it's not actually caster adjustment - it's supposed to be camber). That makes no sense. It really makes no sense when you ponder how he's supposed to adjust camber as they're installed presently. You can't even access the 4th cap bolt (hidden or do they only include 3 lol) so how are you going to loosen the assembly to adjust camber, if this installation is correct? Again, makes no sense.
    Here are more photos of correct plate installation. Again, the inner slotted area is for caster - they always have a screw with allen key head and that action is front to back. Camber adjustment is side to side.
    This is from ground control website..so weird how it's contradictory to what everybody else is saying
      😂 dude, I didn't design them, but they're installed correctly as-is.
      Yes, I used 3 bolts, no issues.
        How do you adjust if a bolt or 2 are blocked? (See gc's pic above)
          Same way you would if you're making changes on your plates, just an extra step
            You have to drop the struts down or cut the tower, see my pic above
            Email to [email protected]
              That's absolutely ridiculous. Install them 90 degress turned and you can adjust camber easily like every other plate.
                Definitely not.
                  Definitely not.
                  Ok. Well, not sure what to tell ya, I have Turners now too
                    IDK what to tell you but a bunch of manufacturers make them that way when there is camber and caster adjustability. Maybe has something to do with that central mount, if you turned it 90* it would run into that inner mounting stud to the chassis before getting enough camber.
                    In fact it is so common....
                      Turners...
                        nextelbuddy how did these end up working out for you? Did you have them installed correctly? How much camber are you able to get from them? I just got a set with my MCS 1WNR, and had similar questions about orientation and set screws getting blocked.​​
                          I recently installed these and they came with a 1WNR kit from Bimmerworld. A few things (I hope this helps someone in the future when trying to search for an answer):
                          1. OP did install them correctly. Yes, to get full adjustment, you either need to cut the shock tower as George Hill did, or drop the shock so you can reach the hidden set screw. I was able to get to -3.9 (my target) without doing any of this, with a bit more camber available. Shifting the whole plate inboard towards the engine helps with this. I simply move it along the caster track to reach the hidden set screw, then set caster last, basically maxing caster to what the uncut shock tower will allow. If I wanted camber deep into the 4s, I'd need to cut/drop most likely. I will probably cut if my shock towers eventually crack, but they looked perfectly fine when I put these on (note: Previous owner was running Ohlins R&T and GC Street plates, without reinforcement plates. I put on reinforcement plates with this install).
                          2. GC's website isn't very well organized, but there are some hidden nuggets in their archives, specifically, showing that they recommend doing what I did to install. See attached pictures.
                          3. The Race camber plates are the same between the E46 M3 and non-M3. This is not the case for the Street plates. I asked GC this specific question and they confirmed, since BW shipped me the plates with a non-M SKU.
                          The car is still in storage mode so I haven't driven it yet, but looking forward to it.
