Exhaust question (Supersprint)
  • x Spades x
    All correct above, except that the transmission brace is three pieces. There’s a little spacer in between the two parts that looks a lot like the small bracket.
    Let me think about a way to get you a set if you can’t get them made.
    I'll purchase 2 sets from ya.
    Maybe we can get a Lil GB going, to make it worth it for ya.
  • Bry5on
    Use this link to purchase all the brackets (5 total parts): https://cart.sendcutsend.com/ygpv6yonwfpq (EDIT: This link is my first design, does not fit without modification. New link coming soon)
    You’ll just need four M8 x 16-20mm fasteners and two M8 nuts for the transmission bracket. Enjoy!
  • SQ13
    Me too, please.
  • Bry5on
    How can I purchase this small AND the transmission bracket from you asap, as i have zero access to the capability of doing this?
    Also, is this part (pic attached) the same stainless steel piece turned vertical, joining two staggered clamps?
    Which would be... 5 of these clamps in total with two stainless steel brackets, and the two piece transmision braket?
    https://www.amazon.com/dp/B08HW8ZF4Z...sin_title&th=1
  • x Spades x
    I am using Bry5on 's bracket and it has gotten rid of the majority of that resonance.
Name:	ssv1 brace.jpg
    Yeah this is awesome. Is this two separate pieces (a top that contours around the tranny and a bottom that connects straight to the exhaust?
  • x Spades x
    Just a laser cut piece of 304 stainless joining the two exhaust clamps. Those clamps are made by evil energy if memory serves. Picked them up off of amazon.
    each bracket helped with NVH, the one that bolts to the gearbox probably the most, then the one at the headers, then the one at the back. Of the latter two, the effect was more similar than the former. DXF for the laser cut piece attached.
    Click image for larger version  Name:	IMG_4107.jpg Views:	21 Size:	84.1 KB ID:	285286
  • 0-60motorsports
    i have resonance as well so im going to be ordering these brackets and i already have the clamps
  • Bry5on
  • Sid_E46
  • SQ13
    I, too, would like a ready-to-install solution to this. I can’t believe a $5k exhaust setup does this. 🤦‍♂️
  • zivagolee
    calling Bry5on
  • x Spades x
    started a topic Exhaust question (Supersprint)
    I've been getting some resonance with the complete 2.5" system and i came across the video.
    Has anyone tried a bracket like this?
    Anyone know what that dual clamp is called (essentially tying both pipes together)?
