Wheel Fitment + Suspensions That Don’t Work Together
    It’s been a long time since I bought wheels and I remember an old thread that mentioned certain offsets not working with front suspension. I’m looking at 18x9.5” et35 and wanted to make sure there wouldn’t any issues with stock or a future suspension I might be interested in.
    I had arc8s in 18x9.5 ET35 and 10.5 ET27 rear w 255/285 on Eibach/Koni and had not clearance issues whatsoever
      Can anyone confirm that 18X10 ET25 square will fit? I am told this is doable with about 3.5 degrees of negative camber in the front.
      Old, not obsolete.
        I have 18x10 ET25 with 275 NT01s, -3.5 degrees of camber, and KW Clubsports which are considered to be low/tight for clearance. But full disclosure, I have not had a chance to finish or shake down the car. So I don’t know 100% how things will be under full compression and/or angle. Should be alright though from what the hive mind reports.
          Thanks Nate.
          Old, not obsolete.
