Changing top mounts
    Changing top mounts
    To remove the coilover spring and damp from the front of the car. Is it just a case of the following:
    Raise the front of the car
    Remove the front wheels
    Loosen the hub pinch bolt
    Remove the 3 nuts from the strut tower
    Finally remove the damper, coil spring and top mount as one unit
    Or is there something i have missed?
    That’s pretty much it. You’ll have to disconnect the sway bar links and on the passenger side you might want to unclip the headlight level sensor from the lower control arm.
