In response to an "Error code 230 - Throttle valve position set point deviation", i saw the following fix procedure posted below. I have never heard of it, have you?
Does anyone know if there is any TIS doc or similar official documentation available?
Turn the ignition key to the on position, slowly depress the gas pedal all the way until you hear a click. Do this 4 times and then start the car. It will reset the throttle position sensor should help that’s where I would start.
