Water leak from passenger door
    Anyone have any thoughts on why this is leaking and how it can be fixed ? I saw water leaking through the door panel. Maybe the seals have gone bad?
    Check the body window seal, if the door harness is clipped in correctly into the body, and the vapor barrier behind the door panel.
      Must be the vapor barrier glue is bad. Make sure the wire/cable/harness connected to the door are sealed at the barrier as it seems water follows the wires.
        Vapor barrier
          Door panel vapor barrier
