Search in E46 (2001 - 2006) only
Vehicle Discussion
E46 (2001 - 2006)
Vacuum leaks after shim adjustment.
ac427
Mar 2020
01-26-2025, 04:25 PM
I heard that vacuum leaks after a shim adjustment are quite common. Is this usually just the valve cover gasket not sealing properly?
How can you test for vacuum leaks?
Tbonem3
Mar 2020
01-26-2025, 04:41 PM
Probably more likely the vacuum lines like the one on top from crankcase seperator to airbox
DD:
2011.5 Jerez/bamboo E90 M3
DCT
Slicktop
2004 Silvergrey M3
Coupe
6spd
Slicktop
zero options
More info:
https://nam3forum.com/forums/forum/m...os-supersprint
