Rear spring platform height adjustment
  • bigjae46
    So you used these with standard TCK 6.5" spring?
    I just ordered a set of 5.5" eibach linear springs as mentioned a post above yours so I can get ~13.25 center cap to fender height which I cannot with the TCKs.
    I have to lower the RE adjusters so much they contact the axle unfortunately.
    I don't have the centering cones or spring pad up top. Just a small carbon fiber reinforcement plate and a WD40 cap to keep the spring from falling out under droop.
  • Cubieman
    I have the RE spring perch in anticipation of the FCM dampers. I used the TCK beehive spring and it works fine. I am at about 25" ride height with 275/40R17 tires so I am not very low.
    I was wrong, these make small adjustments SUPER easy! Love them!
  • bigjae46
    What's the thread dia? Most are 1.5 but coarse at 2.5 starts with M18. Otherwise, 1.75 or 2.0 for m14 & m16.
    Big Jae, re how they work, I envisage a big ball bearing, but I've never seen one disassembled. Clever product. I always seem to use 2.5" & 65mm rear springs so never considered them.
  • moproblems
    Well I guess I am stuck with traditional adjusters until, TCK offers a 5.5" 500lb beehive spring but say it will bind on this chassis.
    Maybe someday if I go to stiffer springs I'll be able to use these RE adjusters.
    My BC's had 5.5" rear springs, they were swifts, I don't know the rate unfortunately but I'm sure it was significantly higher than 500lb.
    I just don't care for the design of the TCK perches, they didn't machine a flat base on the bottom. So there is very little surface area on the control arm.
    I may buy RE'S traditional style perches or maybe just some ebay ones, simple part.
    Eibach makes a 60mm non beehive 514lb/in spring in a 5.5 inch length. Eibach 140-60-0090. 2 inch block height so I wouldn't worry about spring bind or needing a beehive spring.
  • Cubieman
    Well I guess I am stuck with traditional adjusters, TCK offers a 5.5" 500lb beehive spring but say it will bind on this chassis.
  • Cubieman
    Originally posted by prostcfc View Post
    I bought a MCS 1WNR kit from Bimmerworld and they sold me the RE perches and 5" springs. They work.
    Yeah, I have been looking at 5" springs as 5.5" are not so common.
    I would like to stay with a progressive spring if possible. Maybe I'll reach out to TCK and see if they have anything.
  • prostcfc
    I had this all written on a piece of paper that I can't find, but I came to the conclusion they were 2.5 pitch. Pretty sure I even took out calipers to see. I reached out to RE a couple times over email but didn't get a response.
    Anyway, I adjusted today, and assuming a .63 motion ration in the rear, it's about 4 mm per turn, which correlates to roughly a 2.5 pitch. Good enough for me to get a swag. I know these are supposed to be used for corner balancing, but this at least gets me in the ride height ballpark in advance of doing that (I don't have scales).
  • prostcfc
    The TCK springs I have are more or less 6&1/2" tall, what are people using using the RE perches running? A 5.5" spring would be ideal from what I can tell but that's not a very common size.
  • Cubieman
    The RE's won't work with my TCK rear beehive style springs, I would have to run the mounts so low that the threaded rod touches the axle.
    I have the "newer" RE's with a 14mm adjuster.
  • Tbonem3
  • prostcfc
    I have the Rogue ones. Nice product, but doesn't seem like I can raise them while on the ground with my super stiff Hyperco springs; otherwise adjustment is nice and easy.
    Question - is the thread pitch on these 2.5mm? Trying to get a good approximation for ride height adjustment versus putting my finger in the wind.
  • bigjae46
    Here's my issue with a brand new set…the spherical used is at best an F3, as in if you breathe on it it's moving…
    Shouldn't the bearing move freely? Or am I misunderstanding?
  • enjoy_m3
    I have a set of GC that were lightly used and the bearing froze just like Kaiv's video. Super disappointed. Bought used RE ones, older version and haven't had an issue since.
  • fattycharged
  • ac427
    Is F3 a particular type or grade of bearing?
