I've had my 2002 vert for 7 years now, and it's always had a little quirk in the trunk latch -- more often than not, when I push the trunk open button in the dash, or use the trunk button on the key, it'll sound like it tried but didn't quite succeed in unlatching the trunk. Indeed the indicator in the dash will show the trunk open, but if I go back to lift the trunk lid, it's still half latched and won't open. Once it's in this state, to get it to open I have to either use the key physically in the trunk's keyhole, or be lifting the trunk lid with upward pressure while it's failing to unlatch to get it up. I'd say about 10% of the time, it unlatches successfully no problem. I get a code in the body electronics module related to trunk latch: "3D: Trunk-lid unlocking: mechanism"
To describe the sound it makes when failing: if you take the sound it makes when it succeeds (the sound that any of you normally hear when you open the trunk with a button), it's a single definitive click sound. When mine fails, it basically makes that same sound *twice* (and that double click will be how I know it failed before even getting back there to try and open it).
When the car is unlocked, opening using the button under the trunk lid handle to unlatch the trunk always works no problem.
I've always figured that this was the trunk lock actuator itself, and I recently bought and installed a new one (https://www.fcpeuro.com/products/bmw...mo-v20-85-0034). To my surprise and disappointment, it did not fix the problem, I still get the exact same behaviour as before.
Has anyone else encountered this issue and know what the problem is?
