I've got a S54 Z3M in my shop and I am working through some things on it and looking for some insight from the group.
The car has an SGT catted sec 1 on it and it has cat efficiency faults stored. The cats are identified as being made by Magnaflow and between the two of them I have 0 experience with this setup.
For those with these cats, will they set cat efficiency faults on a stock tune?
I've used Magnaflows on S62s and they almost never pass the cat test, I wasn't sure if that was the same with these as well.
If this is "normal" I've got some options to fix it just wanted to see if this is a known issue or we really do have a cat problem.
TIA
********EDIT
2nd part is does anyone have pics or know how the rear O2 sensor wiring is routed? I've been scouring the internet and can't find a definitive pic. I think it should go up the RH side of the transmission tunnel to the e-box, but I am not sure.
TIA
********EDIT
