Air rail o-ring
    Air rail o-ring
    Does anyone know the o-ring dimensions for the air rail tubes? BMW Part #13417830384
    Nope. I’d recommend you just buy a set from bmw. Less risk
    also it’s 2 different o rings for top and bottom
      Incorrect, the air rail tubes use the same o-ring top and bottom. You must be thinking of the injectors.
        ah yeah crap memory fooled me.
          Dropping this here for posterity. If anyone needs the fuel line to rail o-ring it's 13-64-1-730-767. I suggest not trying to start the vehicle without this installed 🤣
            Realoem lists it as: 7,52X3,53
            EDIT: This is for the fuel rail to injector o-ring, not the air-rail o-ring as requested. My mistake.
              Can you post a screen of where you see those specs? Genuine question.
              2006 M3 ZCP
                I'm glad you asked, because I screwed it up. That supplemental info is for the fuel injector o-rings to fuel rail part number listed above (13-64-1-730-767​), rather than the air rail o-rings you requested. There's no supplemental info for the air rail o-ring dimensions on realeom. Sorry about that.
