S54 Build Decisions: Turbo vs. High-Revving NA – Seeking Experienced Opinions
    Originally posted by JeremyJames View Post
    God damn, some of you guys are a tough crowd. Must it always come to this? The thread started off great and as you can see has ended in pure trash, what else is new though.
    Lets reiterate the entire purpose of this thread and my inquiry since half of you clowns didn't read it in the first place, but came here to share your 100% unexperienced keyboard opinion...
    I have an EXTRA operational S54 on an engine stand with a low mile 6spd transmission in my garage. My full intentions are to perform a rebuild on the engine from the ground up REGARDLESS of the route I take, before I started cracking into the rebuild, I was considering the different options that I have based on my end goal for the engine. I never effing said I was going to put it in my current E46M platform, or that I wanted to be a track superstar, or that your mom doesn't give that good of BJs. I just mentioned what I wanted to use the motor for boost or high RPM seeking real life experience from other alike gearheads.
    I know every single thing that I need to know when I see a member with 5,000 post in 5 years slapping absolutely zero value. No life.
    I mean, hash tag #internetlyfe, amirite? Go outside.
    For those that added value and actual experience, I do appreciate you and your input.
    You asked a question thats been asked an uncountable amount of times, in the most active E46 M3 forum on the planet? There will be some strong opinions. Even in the dick measuring posts there are lessons to be learned. Try not to add to the fire with school yard type commentary.
    Go balls to the wall NA build. see what 13.5:1 compression can do, max cams, and vanos delete. This car has been done for 25 years... very rarely anything new happens, and its usually incremental.
    There are parts in EU that are not available here, ie. P54 heads, and other unobtanium hiding in places. M3Cutters might be another source for info and advice.
    PS: I second what 9kracing has said about Anri regarding builds
      Agreed. He comes asking these asinine questions and goes trashing valuable members of the community.
        I performed a few searches before creating the thread here, there is a lot of information out there and I was more seeking personal experience and perhaps some guidence. I do not frequently monitor the forums on random subjects, so I really wouldn't have a clue that this has been discussed before. I created a thread asking questions that were not that wild or animated - truly inquisitive. I do not appreciate the sarcastic comments for no reason at all. Just because that particular member browses the forum so much that he "yet again" must read the same questions - I am sure that happens often.... Either way, added memes and sarcasm brings absolutely 0% of value to the topic. Agree?
        I appreciate your input as well.
          One guy I know for sure on the board who is currently running turbo is nextelbuddy
            lots of talking going on here, im not going to dive into the penis measuring contest of who knows the most about this or that.
            all i can speak to is my experience with My S54 turbo setup.
            i have a street setup making 530 whp at 11 psi on a bottom mount SPA cast manifold and Borg warner S366SXE turbo with a 1.0 AR on the exhaust side. i have a custom scavenge pump setup for my Oil drain as the turbo was a bit larger and hung low preventing a good gravity drain.
            i have no engine work done, completely stock and was turbo charged when i had about 135k miles. i've put about 10k miles on the turbo setup now with no major issues.
            i run no cats and just a 3 inch down pipe mated to a dual Y pipe into stock section 1 resonated and status gruppe non resonated section 2 and status gruppe SCZA section 3. my car is not loud and sounds like a stock turbo car and i love that part, no more screaming engine exhaust sound when pulling away in traffic which i hated, nothing like a loud ass car making so much noise and not going anywhere
            the car is on a stock MSS54HP DME with a custom HTE turbo tune running E85 100% and the car drives and feels like a stock car just much much faster which was my goal ultimately.
            could i track my car? perhaps but I dont run an aftermarket oil cooler, just a stock one and i have a stock cooling system (all updated from FCP but stock parts)
            my oil temps on the street barely ever reach the middle mark compared to my S54 wagon which does exceed that mark on hot days but i am taking a guess that my turbo car runs e85 so engine runs a bit cooler, my custom oil drain setup also incorporates a small aluminum sump tank hanging off the turbo which probably also helps cool my oil along with the additional lines.
            i also have an S54 SMG wagon with CSL airbox, euro headers, cat delete and stock section 2/3 and its just louder and its ok. definitely not as fun as the turbo car but for a daily driver its all i could ask for and exactly what i wanted.
            let me know if you have any questions about my turbo setup specifically. or want to see or hear videos.
            If you go turbo and stay stock compression, you need to run e85 to run more than 10 psi of boost. pump gas detonates and you need to run meth injection OR e85. running stock compression ration definitely makes good peppy power. you can run 9:1 but have to run more boost and need more tuning and you lose some of that low end spool and tq
            my turbo car has unopened S54 stock everything with about 145k miles on it
            my wagon has a rebuilt S54 with new rod bearings, HG and all new valve stem seals and every other gasket and seal replaced.
              I have a fairly modified NA car and a decently modified SC car.
              I don't have direct experience with a turbo S54 but I have friends with them.
              My advice:
              Aside from headers, intake, lightweight wheels (under 18 lbs a corner, no Apex bullshit), better brakes, decent coilovers, better seats, and a short shifter, I'd leave it alone.
              If you're chasing some special engine, it's already a special engine. It's on the spectrum.
              2005 BMW ///M3
              Black6MT Daily
                Building an n/a s54 is very expensive and it will be totaly unrelieble, i have started with decat and no name carbon airbox, this set up ended with fully ruined engine , because only few tuners in the world know how to tune it, after this we build engine with 11.5 compression, +0.5 je pistons ,fcp rods, balanced cranck and schrick 280/288 cams with supertech springs. Then one other guy tried to tune it without any numbers 315hp to understand , after we tune it with evolve , wich is crap tune also , 330hp, finaly i have spent hours reserching and found one guy named Paul Cloud , pcs tuning ,finaly with Paul we made car safe and fast last dyno attached (superflow) 98 octane with vp fuel madditive. After few track days shricks turned into garbage, in some places like new in some got wear as it was half million km , when we made test in lab , expert made conclusion that it was incorectly hardened , shrick refused in warranty so from thos moment we dont use schrick in any builds.
                  Car specs : karbonius race air box, stock ecu ,pcs tune, csl map, je pistons +0,5, 11.5 compression,balanced cranck, fcp rods, driftworks flywheel,sachs race clutch, supersprint raceheaders, custom middle section, arqray titanium rear box (9kg) stock fuel sistem
                    The HPF experiment was quite interesting years ago. IIRC, 33psi was the ceiling on stage 4? I don't see many of those cars still going. I'm positive I'd see them on facebook and instagram. But you can get to 420whp pretty easily on 7-8psi of boost? I don't think that will stress the motor very much. Your issue will be managing heat. I think you destroy the intake noise since you'll need a different intake manifold.
                    An NA build would be far more interesting. I think the comments above about - it will be expensive - all miss the mark very badly. Yes, the parts won't be cheap. But here is why I say that.
                    The biggest concern is build quality which translates to reliability. I've seen far more cases of engine builds gone wrong vs gone right. Probably a 9:1 ratio which is quite bad. Tip #1, using a racing shop is usually the wrong answer, using a machine shop is a terrible answer. They know a decent amount about a lot of stuff, not the expert on engines. A while back, I had an enlightening encounter with a shop that builds motors for dune buggies. Those motors spend hours at redline so those motors have to be precisely designed and built. So I'd do a ton of research outside of the forum to find an engine guy.
                    The one guy I would trust with a reliable stroker build would be Steve Dinan, not the Dinan parts shit show, the actual guy who has a long track record of building NA BMW S engines that won IMSA 4 years in a row with a 20 year old engine. And that guy's labor will cost more than the parts.
                    That is where most go wrong. They hire some ape who talks a good game and it becomes a roll of the dice. And picking the wrong engine builder is an expensive mistake.
                    Personally, I'd love to throw in a B48 with 420whp. Those engines should be cheap, easy to find, and fairly reliable even with more boost.
                      The Steve Dinan/Carbahn stroker stroker s65s don't seem to be the most reliable, and they don't even start out undersquare like S54. I don't think a stroker, by anyone, is likely a long term reliable S54 solution.
                        I'm just talking about the engine blowing up soon after the rebuild. Revving the S54 to 9500 RPM will significantly shorten the lifespan of the build, no way around it.
                        Is the S54 a decent stroker candidate? I thought there wasn't much material between the cylinders to start off with. I know there are 3.4L and 3.5L kits floating around, haven't seen many stroker builds. The only one that comes to mind is Garo Haroutianin (spelling?) in the orange hill climb M3 with a VAC stroker S54.
                          What you should really be doing is calculating the piston speed to see how high the mean / average already is on the S54. To keep this to a manageble level, you want a small stroke (hence why you see the term "de-stroked" (which reduces the engine capacity for a given bore size (and vice-versa).
                          At 8000 the S54 for has a high 24.267m/s average. Due to the relatively large stroke (91mm), increasing that to 9500, takes it to 28.817m/s average, which is WAY to high for any engine longevity - the strain on the rods will be huge.
                          As an example of a high revving engine (F20C), which goes to 9000, due to it's smaller stroke (84mm), so despite the higher rpm, it still only has an average piston speed of 25.2m/s.
                          A 458 has an even smaller stroke of 81mm, so it's same 9000rpm redline as the F20C has practcally the same piston speed (24,3) as the S54 does at 8000rpm.
                          The S65 is even lower, with a stroke of 75.2, so even with it'ts 8400rpm rev limit, it has a low 21.056m/s average.
                          So basically the S54 is already on the limit of it's design at 8000rpm (8300 would give it the same piston speed as the F20C). There is no way to gain any capacity due to the bore spacing. What would have been nice if BMW had continued the development of the S54 in the same way that Porsche did with their flat six. Imagine a 4.0 litre, 14.5:1 straight six with an 84mm stroke - that would be safe to 9000 and should make a comfortable 500bhp N/A.......
                          Not sure if would still fit in the E46 engine bay due to the requirement of 100mm bores giving at least a 78mm extra block length (100mm to give some meat on the wall thickness), but we can dream LOL.
                            I was going to quote you and ask if you had a reason high RPMs would be unreliable, and then my hero posted below you and basically said what I was going to.
                            When you start talking about those kinds of RPMs you have to take into account a myriad of factors, such as piston speed, rod stretch, etc.
                            2004 Dinan S3-R M3
                            2023 X3M Competition
                              Do you have any photoes of damaged schricks? I've bought ones- silver ones, without coating and seems like same problem
                                Known issue and documented now in new manufacturing process. Gone is the usual old school black nitrided coated lobes. All new cams now come polished, forcing your hand on buying the new dlc rockers (the correct way to install but was not always the case, members here with older engines around 200kms fitted 288/280 cams on oem followers with no issues). This happened to me in 2023 when I installed 280/272 cams.
