Noise diagnosis help *Updated with fix*
    Looking for help on what this noise might be. Happens over rough roads, even happens going over the slightest bumps. Metallic clanging coming from the rear
    *Fix* - One of the exhaust hangers was slightly loose
    ‘02 TiAg/Impulse Slicktop
    Sub Frame Crack?
      Sub Frame Crack?
      Sounds to rattley/loose to be the subframe. No cracks upon visualization without taking the subframe off
        The sheet metal pulled apart, making contact, sounds a lot like this actually. Pull everything out of the rear and inspect topside, leave it out while driving…it'll get louder
          Interesting….ok I’ll give it a try, thank you!
