Thanks everyone for the help on my earlier post. But now I’m afraid I’ve gone too far. So I am doing the Vanos bulletproofing. While waiting on the timing tool to show up I went ahead and removed the Vanos unit. I did NOT touch any hub or cam bolts. Today the timing tool arrives and I start on the TDC procedure. After a couple turns I feel a resistance change and realize that the helical gears have came out completely and the cam gears and timing chain are turning but the camshafts aren’t turning. How far how I’ve messed this up??
Thinking this through, is my solution to: put the car at TDC, place the pin, take a 24mm wrench to turn the cams until they are in the correct position, and then continue the normal work? How far and how safe is it to turn the cams by a wrench? This felt well within my mechanical capabilities but now I am questioning my sanity.
Is this how Vanos works??
