TCS & Brake Indicators
    Anyone experienced their TCS and brake light illuminating randomly while driving then going away after restarting? Been happening to me but only when it rains.
    I would check your wheel speed sensors are fully intact as in no exposed wiring, good connections and make sure there is no water potentially getting in.
      It could also be your yaw rate sensor. Mine blew and after replacing it both lights went away.
      My TC and brake light were constant though, not intermittent.
      '02 M3 Oxford Green/Cinnamon 6MT
      '11 M3 ZCP Apline White/Black SMG
        Yes, but I would scan the DSC module for faults with INPA or similar so you have a good starting point. There are a few threads on here this with good info. For me brake pressure sensor faults were appearing, though I checked the sensor values with INPA and there didn't seem to be an issue with their functioning. Some have had success changing brake fluid, which I did prior to a track weekend, and I haven't had an issue since. I'm guessing yours will be a different cause if it only happens in rain.
