I wouldn't use anything other than a hose on the radiator/condenser, as a pressure wash could easily damage the fins
A/C causes higher oil temperature gauge reading
What do you see between them? Most debris caught by the front condenser. You can use pressure water hose shooting through the fins from the engine side to clean the dust off.
Did the fan run strong at 100% inpa control command?
I could hear the fan accelerate and decelerate though.
I kinda have similar issue, when I replaced my water pump, I saw rust in the pipe on the engine side that plugs into the water pump. I assume this is likely because POs used tap water. I now assume there is debris in the system that could be causing some blockage. My plan is to flush it with rust remover (saw a Youtube video by ShopLife) and that seems to clean it up. Don't know if it will do anything for the temperature but something to think about.
Originally posted by 6speedS54 View PostI kinda have similar issue, when I replaced my water pump, I saw rust in the pipe on the engine side that plugs into the water pump. I assume this is likely because POs used tap water. I now assume there is debris in the system that could be causing some blockage. My plan is to flush it with rust remover (saw a Youtube video by ShopLife) and that seems to clean it up. Don't know if it will do anything for the temperature but something to think about.
Unfortunately my version of INPA allows a test of the fan but without the option to choose a desired speed.
So you don’t know it running at 50% or 100% speed?
I'll try a different VM with INPA to see if i get the fan control input everyone else seems to have.
Which version of INPA are you running?
I'm pretty sure mine is from BMW Standard Tools v2.12 but the install is a few years old now.
