Trying to do a full bleed after replacing OE lines with SS lines. No leaks seem to be coming from any of the lines. But I left the brake pedal wedged overnight with a piece of wood to keep pressure in the brake system and there seems to be seeping coming from the bleeders. They are already pretty tight. Any ideas? I made sure they were tight with the small flare nut wrench I had, I dont think I could have over tightened them. But looking at the torque specs these are like 3.6 ft-lb which is almost nothing. I have never used a torque wrench on a bleeder, but I also have never had one leak like this.
Planning on pulling the bleeders out and inspecting them tonight, just curious if others have had the same issue before?
TIA
TIA
