Ya I don't know the difference, if any between, the pad faces of the OE 345mm rotor and any 355 rotors.
This could be interesting. So instead of 5.5mm to accommodate 345mm radially, only 0.5mm to accommodate 355mm? Is pad sweep affected?Originally posted by Tbonem3 View PostI've been curious, what if you only machine .5 mm off the 996 caliper and fit it on a 355mm rotor? Not sure if there's a 355 that's only 28mm wide though. But the calipers *should* be able to accommodate a 30mm I would guess.
996 kit is better for e36s where they run 325mm rotors up front which are in abundance.
I sent an email to GiroDisc as well – they're local to me, but they don't make any other 345mm applications so I have a feeling that's a long shot. They do make 325mm, originally for Porsche rears.
I chatted with a rep and he said they will be offering rings but wasn’t able to give me a price atm.Originally posted by r4dr View PostInteresting. I guess the real question is whether they're designed to have replaceable rings (they must be... that would be insane otherwise) and what the costs are on the rings.
That's the biggest downside to me for this caliper swap – there are no good options for rotors IMO.
I feel the same way, the current offering of rotors for the 996 swap are limited and dull. Which propels the Turner offering to the top of the list imo.
Turner Motorsports recently released their TrackSport two-piece fully floating rotor sets (front and rear)Originally posted by r4dr View PostHave non-drilled rotors ever been able to be found for this swap?
They look promising since they are a true two-piece design, slotted, and made to OE fitment and installation.
Price is a little on the high side specially since they currently do not offer free shipping.
The current 10% off brings the price per rotor down to $422.95 per front rotor and $404.05 per rear rotor which is not bad given they are the only offering for our M3s that are available with matching front and rear rotors. (that i know of atm)
PFCs go for $521.99 per rotor and they only offer a front set.....
It looks like a may need to be a bit more aggressive with bedding. I have done it twice, but both times I have done about 6 stops from 60-20. I sounds like I may not be getting enough heat to put down a really good transfer layer. I am guessing the noise is coming from the faint machining marks on the brand new front rotors interacting with the pads at those really slow speeds / light pressure. During normal driving and most stopping, everything is silent.Originally posted by S14 View Post
sounds like you need to bed the pad compound into the rotor (are the rotors new?) to make the two materials familiar with each other. Get the car up to 60mph and firmly slow down to 10mph, then speed up to 60mph again, back down to 10mph. Do this 8-10 times over and over again and I bet the noise will go away.
sounds like you need to bed the pad compound into the rotor (are the rotors new?) to make the two materials familiar with each other. Get the car up to 60mph and firmly slow down to 10mph, then speed up to 60mph again, back down to 10mph. Do this 8-10 times over and over again and I bet the noise will go away.Originally posted by designer485 View PostHi guys, I just finished installing my setup (Front and Rear). Rally Road Brackets and Lines, Textar Pads. I have about 40 miles on everything so far and I am getting a very loud screech / squeal when lightly braking from about 25mph or so down. Sometimes not until 5 or 10 mph depending on pressure. Bedding everything in seemed to go well and everything feels great (pedal feel, bite, etc.).
Did anyone use Brake Lube on the pad backs, spring clips or pad guide pins? As anyone else getting noise like this?
It is slightly embarrassing coming to a stop with my brand new brake kit sounding like a school bus...it would be one thing if i was using race pads, but these are OE Textars and should be nice and quiet.
Thoughts?
i have this issue at the rear. I was using brembo ceramics before but installed Textar as they brake better being metalic, but they squeal just like you describe. I have been lazy to try the rubberized thicker plate the brembos have, that was the main difference between the two. I may do this this week.Originally posted by designer485 View PostHi guys, I just finished installing my setup (Front and Rear). Rally Road Brackets and Lines, Textar Pads. I have about 40 miles on everything so far and I am getting a very loud screech / squeal when lightly braking from about 25mph or so down. Sometimes not until 5 or 10 mph depending on pressure. Bedding everything in seemed to go well and everything feels great (pedal feel, bite, etc.).
Thoughts?
It almost sounds like you didn't bed the brakes. Mine made more noise before bedding the brakes. It shouldn't be a very loud screech / squeal thou.
The pad vibration plates stop the metal clunk when applying the brakes caused by the caliper pistons hitting the back of the brake pads. When using them you have to remove the calipers to get the pads out. I did use them but removed the 3M adhesive that sticks the brake pads. I still have the clunk but 50% less using them if that makes sense.
The sound is coming from the front, although I did take the small pins out of the rear pads (there was no way to fit them without taking those pins out). The front caliper guide pins have good clearance on both sides of the rotors. I did not use pad vibration backing plates as it looks like a 50/50 spread here with those who did.Originally posted by duracellttu View Post
Did you take the metal circling out of the one set of pads? I think it was only the rear. Sounds like you have metal on metal contact some place. Your best bet is to get the car back in stands. Remove the wheels and do a thorough visual inspection of the calipers, rotors, and pads. Possibly remove the calipers from the adapters as well. Check the clearance between the pad guid pins and the rotor rom the inside of the caliper while you are at it.
I didn’t uses any brake/assembly lube. However I did use the clips that keep the pad attached to the pistons.
Should I be ordering some? It seems to back pad changes a lot more time consuming if used.
Everything is silent except for that 10-15mph at low pedal pressure. I have no problem having another once over and taking things back apart, but before I did, I figured I would check with the group to see if anyone ran into the same issue.Last edited by designer485; 09-21-2020, 08:14 PM.
Did you take the metal circlip out of the one set of pads? I think it was only the rear. Sounds like you have metal on metal contact some place. Your best bet is to get the car back in stands. Remove the wheels and do a thorough visual inspection of the calipers, rotors, and pads. Possibly remove the calipers from the adapters as well. Check the clearance between the pad guid pins and the rotor rom the inside of the caliper while you are at it.Originally posted by designer485 View PostHi guys, I just finished installing my setup (Front and Rear). Rally Road Brackets and Lines, Textar Pads. I have about 40 miles on everything so far and I am getting a very loud screech / squeal when lightly braking from about 25mph or so down. Sometimes not until 5 or 10 mph depending on pressure. Bedding everything in seemed to go well and everything feels great (pedal feel, bite, etc.).
Thoughts?
I didn’t uses any brake/assembly lube. However I did use the clips that keep the pad attached to the pistons.Last edited by duracellttu; 09-21-2020, 07:53 PM.
Thoughts?
