Just getting parts ordered for the 996 calipers but currently running with ARC 8s
Front: 18x9” ET30 with 245/40-18 tires
Rear: 18x10” ET25 with 275/35-18 tires
I’ve seen a few state that a 5mm spacer will work up front but Apex suggests a minimum of 3mm gap between spokes and caliper and that an 8mm at a minimum would be needed. Anyone confirm 5mm will work?
I installed the front 996 calipers on my 2004 convertible yesterday.
The process was mostly straightforward, but I encountered one major challenge: the 16mm carrier bolts. There was an excessive amount of Loctite on these bolts, so I had to use heat and PB Blaster to remove them. Even after applying heat and the blaster, it was extremely difficult to break them free.
This issue was frustrating and turned what should have been a one-hour job into a three-hour endeavor. If anyone faces a similar problem, I recommend removing the discs to gain better access to the carrier, which will help you apply heat more effectively.
I used Rally Road brackets (older style that I bought back in 2013) and did not have to grind anything to achieve a good fit.
I run the following for track pads:
PFC 08 0776.08.16.44
PFC 08 0776.08.17.44
Welcome to the forum.Originally posted by ca86108 View PostHello Everyone,
I just purchased my e46 m3. The car came with this exact conversion. Can you all help me with the following questions? Thanks
1. Can anyone recommend some more aggressive pads for front and rear? Can you send me the direct link or part number? I feel the stock Porsche pads are kind of soft and don't stop really hard with aggressive driving.
2. I see conflicting answers to this question. Is this BBK conversion from a 996 Turbo and a Cayman S? I see some websites saying they sell the pads for with the part numbers but they say (except for Turbo models, or Except for Cayman S). If I was to go to a shop to rebuild the calipers, what car do I say these calipers and set they are from?
3. Are both the front and rear 4 pot?
Thanks for all your help
Right from the Rally Road site (most conversions are done using their kit):
Front:
Calipers used for this conversion are Front Calipers from the 1999-2004 Porsche 996 (non-turbo), the Boxster S or the Cayman S. All these calipers are made from the same Brembo casting.
The Porsche caliper part numbers for this conversion are:
996.351.425 (driver side)
996.351.426 (passenger side)
Rear:
Calipers used for this conversion are Rear Calipers from the 1999-2004 Porsche 996 (non-turbo), the Boxster S or the Cayman S. All these calipers are made from the same Brembo casting.
996.352.421 (driver side)
996.352.422 (passenger side)
Both front and rear are 4 pot.
I will leave the brake pad recommendations to others.
Hello Everyone,
I noticed something weird with not using the using the backing plates with the adhesive. After about 15k miles, the front rotors wore unevenly. The inner and outer and outer edge of the rotors wore ar minimum spec while the middle of the rotor was only about .6mm low. Minimum spec is when they wear 1.6mm. The rotor surface was rounded and the inner and outer edges were actually pretty even in measurement while the thickest point was in the middle. I used proper pads because when I went to my Porsche parts for new pads, they were exactly the same. I think I may be a one off in this but this is a heads up to check to see if this is happening to you.
Costs are definitely higher now for everything. No question.
As far as MK20 is concerned, that won’t matter unless you’re tracking the car. And even then it won’t be a massive issue if you don’t have aero and slicks. If it becomes a problem, you can retrofit the MK60 and at that point, look into other more serious BBK options.
I may have a line on a set of these, whats a good price ebay seems to have them over 1K CAD? Just wondering where people are sourcing there rebuild kits? It seems since the original posts were made in 2020 lots has changed. looked at several of the mentioned sites and either nothing listed or not available. I would prefer original Brembo if possible.
Also, any issues running these with a MK20 ABS car? I have an early 2002.
For street use prob doesn't really matter that much, Akebono, Textars, etc.Originally posted by Ubaderb View PostFor anyone using front Porsche calipers with stock rear, what pads are you using? Just for street use right now, track pads seem a little easier to find info on.
Just so you are aware with that front/rear setup, you are running underpowered fronts with stock rear, shifting your bias to around 62-63%. As long as you are aware/prepared for at threshold track experiences. Can definitely work around it by running much higher mu front pad, keeping as much weight in the rear as possible (muffler/battery/seats), tighter front compression/rear rebound, negative rake, blah blah, but anyway, all of that has other associated handling repercussions.
Yeah, most doOriginally posted by Pklauser View PostDo people code their MK60 ABS to the CSL bias with this setup? Being more rearward, like the CSL, I'd think so, but not seeing anything definitive.
