Decided to casually do headers tonight because a local warehouse had Megans in stock and how bad could it be? 6 hours later I have all 18 nuts out but feel like I'd rather push the car into the ocean than finish the job. This feels so much worse than the 6MT swap did.
I've gotten the bank 2 header loose, but can't pull it out because the bank 1 header's in the way, and can't seem to get the bank 1 header free from the block. Worried that a pry bar will marr the head where the headers are supposed to seal. Any good tricks here?
Also, I expect the answer is just patience and misery until it's done, but, any secrets that make accessing some of the harder nut positions easier for installation? Getting some of them out made me say some pretty terrible things. I'm already using a flex-head ratchet with extendable handle and a u-joint.
Will also be return the Megans if a local set of Euros is still available tomorrow. This job just doesn't feel worth cheaping out on, even if the Megans are probably the same performance-wise.
