CSL intake and Georgia emissions...
    Has anyone here installed a CSL intake in a Georgia county requiring an annual emissions check?
    In Georgia there is no visual inspection, just the OBD and fuel tank cap, so the presence of the intake itself should not present a problem. What I don't know is if the CSL tune required to utilize the intake will make changes to the DME that will result in failing the OBD test.
    Thanks in advance.
    Old, not obsolete.
    Won't be an issue as long as the all the emission devices are working properly.
      I pass fine with CSL software in Cobb county. There can be issues getting the ECU to communicate with the emissions machine using 0401 software but I have not experienced it.
      2003.5 SG/Grey
        Thanks gentlemen.
        Old, not obsolete.
          Good info in case i import my M3 into the States as it'll probably be in Atlanta.
            If you come let us know so we can give you a proper welcome.
            Old, not obsolete.
              Thank you so much! I'll be there in October to November for a visit.
                Right on! What part of town?
                Old, not obsolete.
                  Will message you to connect. Alpharetta.
                    You should post something in the Southeast section. Lots of members in the Atl area :
                    Southeastern US - NA M3 Forums
                      Great idea! I will do that near to the time of my visit. Thank you.
