Pressure Washed My Radiator!
    I’ve seen my coolant temps on track go from about 178-ish to 190 since I had a massive oil leak 18 months ago. I want to limp this radiator along a little longer until I get to a ducted radiator project.
    So I borrowed this Harbor Freight pressure washer from my neighbor.
    Click image for larger version  Name:	IMG_5245.jpg Views:	0 Size:	88.2 KB ID:	318838
    I sprayed industrial strength simple green diluted 1:1 and it came out pretty good! A lot of grit and grime came out. Sorry, no before pic but let’s say you couldn’t see the CSF logo.
    Click image for larger version  Name:	IMG_5243.jpg Views:	0 Size:	131.2 KB ID:	318839
    Click image for larger version  Name:	IMG_5244.jpg Views:	0 Size:	136.2 KB ID:	318837
    Yeah, it’s beat up. Figured worst case the washer bends up more fins and then I replace it. Didn’t bend any fins at full blast. It was interested to see how the water traveled through the radiator. It surprisingly came out the back side at a similar rate across the entire radiator despite the bent fins. The radiator also slowed the velocity of the water by A LOT!
    Washing the oil cooler tomorrow. I taped off and covered the ports for the cooler lines. We’ll see how it goes.
    is that all bent fins or dirt under the CSF logo? Plan on doing the same thing. Also, can you wash the AC condenser as well?
      AC condenser FTW
        Bent fins. I deleted the AC. The lower quarter gets beat to hell on track.
        I'm sure you could but wouldn't be worth the cost to evac and recharged the AC to remove it. Could try to do it in the car with an angled pressure washer nozzle.
