Hey Everyone !
Trying to set my car up for street usage.
It was set up on KW V2 coilovers, with an alignement done by Delage in France. I absolutely loved how the car behaved. It was very good at turn in, as if the car really wanted to take the corner. You hadn't to fight it or force it to turn. It was very slightly oversteering, but very very manageable.
I am trying to find that again.
Car is not on Eibach coilovers.
Suspension setup :
- Eibach Street S coilover with linear springs
- OE front and rear sway bars
- Turner Motorsport street camber / caster plates
- GC rear shock mounts
- Stock rear camber arms
- RTABs with limiters
- Everything is good and tight with very low miles on it, all the bushings / balljoints have been changed so geometry is really under control
Current setup :
What is your input on this setup ? Is the feeling I have in accordance with the setup ? What would you modify ?
So please, suspension gurus, chime in !
Suspension setup :
Current setup :
LEFT | RIGHT | |
FRONT | ||
CAMBER | -2°14' | -2°13' |
CASTER | 7°30' | 7°33' |
TOE | 0°14' | 0°14' |
REAR | ||
CAMBER | -2°20' | -2°25' |
TOE | 0°05' | 0°09' |
