I have an M3 that hasn't been driven in ~10 years. I've been slowly tearing it down for repairs and maintenance. I removed the thermostat housing and waterpump and found white buildup in the housing and pump and rust in the coolant passages.
Does the sludge indicate I need to replace the head gasket, or could that be caused by something else? When I dropped the oil pan to do the rod bearings the oil wasn't milky. When I drained the coolant, it came out clean.
Rust in the passages could indicate incorrect coolant, tap water, something else? Can the rust be flushed out? Or is this block cooked?
