Driver side door doesn't unlock with key fob or center console unlock button
    Originally posted by Barracooda View Post
    so I'm fairly sure it's the actuator.
    You will be surprised it's the pitted relay contacts. How do you know it's the actuator and not the relay?
      Originally posted by simon_c View Post
      Technically it's still true because it doesn't work for unlocking no?
      Well, the console lock/unlock is not a variable here as it's already not working. The title implies the console switch can lock the door (as the fob lock button).
        Good point, I hadn't considered that but it could certainly be causing the actuator not to receive full voltage. It's sure a hell of a lot easier swapping a relay than an actuator, I'll test it out.
        EDIT: dammit, the relays are in the GM5 module...
          If you have a power supply then connect 15v to the front jumper posts engine off (one volt higher than 14v with engine running) and see if the pitted contacts can kick the actuator to work.
