DSC question - MK60
    DSC question - MK60
    Does anyone knows if DSC reacts in anyway to the front inside wheel lifting? Does DSC cut power/apply brakes or ignore it?
    I have a problem were in a couple of spots DSC will apply brakes and I am thinking it might be due to my front inside wheel lifting. Have not checked, but maybe that caliper is somewhat hanging and slowing that wheel while its up in the air.
    Is that possible?
    Do you have the light flashing on your dashboard ?
    If yes it's the DSC.
      I know for sure its DSC, I can feel the brakes being applied. Yes, the light flashes.
      I just don't know what is causing it, if it could be the wheel loosing contact with the ground causing it or if its something else. It only happens on some pretty high speed/tight corners, and I know my Ohlins have very little droop travel unfortunately.
        Turn DSC off bruh
          Turn DSC off bruh
          This happens while driving on the street, while not doing anything stupid. I have turned DSC off to test and the problem goes away, but that is not convenient or normal.
            M track mode for the street!
              Bro...ain't no way you're picking up the inside front wheel on the street unless there is something really wrong with your suspension. You've got to be on full power with a decent amount of yaw in the car, pulling at least 1 lateral g.
              Let's not even get into the grip levels of street pavement and the heat in the tire needed.
                Log wheel speeds while it happens. That might provide some insight
