Adding to the experience. Don’t know if mine experience is universal. I just bought a 100k mile e46 m3 coupe. The engine had a little valve tick when I got it so I did an adjustment. Tick got better and didn’t think anything of it.
fast forward a few weeks later while prepping the car for autocross I decided to refresh a few things. Injectors, fuel regulator, filter, pump, intake etc. diff fluid. typical 100k mile deferred maintenance stuff.
after the car was put back together the tick turned into a very sharp metallic tint tiny tint that sounded from the back of the engine bay / bell housing / under passenger seat.
since I just redid fuel system. I thought it was the regulator bouncing cuz of the new injectors ticking. Didn’t think much of it.
after autocross the sound for even louder so I started diagnosing. I chased up and down the fuel system. Disabled injectors 1 by 1 by disconnecting coil.
found the sound to be not in the fuel system with a stethoscope. I hear it in the exhaust pipes and bell housing as well as only the valve cover bolt closest to cylinder 6 exhaust.
after chasing down and tracking the frequency tied to rpm I figured this is cam shaft related at 7.5 hz at 1000 rpm’s.
so I opened up valve cover to check clearance.
what I found was the exhaust side was completely out of spec. Something that I just did within spec a few weeks ago everything was off.
starting from cylinder 1 through 6. Everything needed bigger shims increasing.
Cylinder 6 went from 2.18 to 2.62!!! A good .4mm increase which is almost unheard of.
Cylinder 1 went from 2.28 to 2.32.
net net the only thing I can think of is the engine mount changes the geometry on an old engine. This is something I’ve not found anyone report before so adding to the internet memory and hopefully this’ll help someone at 2am pulling their hair out.
Net net. Do your mounts before doing valve adjustment. Or after you change your mounts revisit your valve adjustment.
Now my engine sounds like a very healthy s54.
