DIS Working Copy
    DIS Working Copy
    Hi all,
    Need some help with DIS. I paid $50 for the software, but it only worked once before it started freezing. I’ve sunk hours into troubleshooting via three different laptops with various OS installs (XP/Win7, 32 & 64-bit), but nothing works. Now it looks like my activation code has been deactivated.
    Does anyone have a lead on a more reliable DIS download? I’m trying to rule out a hardware fault, and my ISTA contact is coming up empty. Any help is appreciated!
    I probably have a workable install somewhere. What are you trying to diagnose though? Inpa/tool32 should be able to do everything DIS can and then some
      I’ve invested too much into this to let it beat me now.
        https://www.pss-autosoft.net
        For some reason that link isnt working on here, but I was able to access to site. I got a woking copy of DIS from there years back.
        Works fine but is still a pain in the ass, if I had to do it over again I would get an ICOM/ISTA for the vanos test.
        That's the only reason I needed it, but I guess INPA will do a vanos test as well, never tried it myself.
          Actually that might be something we legitimately need DIS /ISTA for. Probably possible to write a script that uses some combination of tool32 commands to do the same thing (since that is essentially what DIS does). But I've still yet to figure out how to actually figure out how those DIS / ISTA scripts are encoded
            Easy way to get those old DIS VM's to actually work is to have a slow laptop with a mechanical hard drive, not a modern solid state.
            It seems some kind of race condition happens shortly after bootup if the disk is too fast.
              I can't say if this is why my version worked or not, but I loaded onto a shitty pawn shop laptop, with a traditional HDD, low memory and just enough space to install the program.
              Mario at pss autosoft had a great set of instructions, its one thing to simply install the program but actually connecting to a vehicle was the most difficult part.
              It looks like you can still contact him on FB as his website seems to be down.
                Thanks for the help, everyone!
                Cubieman, Brilliant info - I bought this from PSS-Soft, so the site being down explains the activation issue.
                bmwfnatic, thanks for the tip! I’ve only been using SSDs laptops, so I just picked up an Asus Eee PC to make sure I have a Windows XP machine with an HDD!!
                  Talk to Mario directly, hopefully he is still active in some capacity, FB? He was of great help to me.
                    I remember sunking a few hours to get DIS running, now I just hope this old laptop never dies because I'm not sure I could figure out how to do it again
                    Alternatively you can get ISTA download links from member shawnsheridan on e90post. I use it on newer cars but IIRC it has all of the same functionalities as DIS for the E46 and is a lot quicker and easier to setup.
                    IG: @limited.slip
                    Alpine White 1 Series M Coupé
                      Is there a way to get ISTA to do a vanos test without an ICOM cable to your knowledge?
                        Thanks Cubie
                        Done! Mario sent over some new download links and troubleshooting guides. With a dedicated XP laptop and an old HDD, I’m on the road to victory!
                          I found the Tool32 test program to be very useful for testing the vanos with the regular d/k can cable. https://nam3forum.com/forums/forum/s...5697#post35697
                          Build Thread:
