How do I insert this annoying motion sensor bracket to the car? I pulled the old one off with all the broken clips by brute force, breaking it almost in half, but now I don’t have an idea on how to place the new one on through the headliner. Apologies for such a trivial question, I’m just stuck trying to figure this possibly easy one out.
Replacing headliner motion sensor alarm bracket?
Originally posted by vp special k View PostIm actually dealing with the same problem.I havent tried it personally but Im thinking the easiest solution, that is if you have a sunroof is to pull the sunroof trim off and then pull the headliner down low enough to slide bracket back in.2002 BMW M3 Coupe Jet Black/Black
2021 Tesla Model 3 SR+ Deep Blue Metallic/White
Originally posted by OEMaddict View Post
I saw someone post that in another forum, is pulling off sunroof trim easy to do and exposes the space between the headliner and trim? Seems that you'd have to adhere it back on after pulling it off or am I wrong?
rotate it 45 degrees and insert a corner in, pull the headliner down a little bit, bend the bracket like a taco, and slide it in
it's unnerving to do, i thought i was going to break the plastic piece, but i did it this way because i was too lazy to remove the headliner and slide it in from the top
Originally posted by ViN View PostI am dealing with the same issue. some of my clips broke and the few shops I have gone to so far said I would need to remove the entire headliner 😏2002 BMW M3 Coupe Jet Black/Black
