VOA BMW M TwinPower Turbo 10W60 Synthetic Engine Oil 83212365944
    Just sharing in case this is helpful for anyone.
    Build Thread:
    Cool, it's a good oil. No Mo result? Should have around 150-200 ppm. I think the latest version of this is one of the best 10W-60 available. Very low Noack, good additive package.
      Supposedly, it's back to Castrol (BP)
        BMW changed back to castrol I think around '21 or '22?
        I use BMW oil because it is the one oil that has been proven to not cause issues over multiple cars. I'm sure there are other oils that are fine but rather stick to something I'm sure works.
          Yea the Titanium, is indicative of it being Castrol to my understanding. Looks to be working good in my use case
          Build Thread:
            Looks very similar to the 2013 Castrol TWS which would make sense.
            Archiving this here as well
            2013 Polaris voa, 2009 Blackstone voa
            aluminum 8 2
            iron 1 1
            silicon 7 4
            titanium 47 0
            moly 198 2
            boron 59 109
            calcium 2823 1141
            phosphorous 804 641
            zinc 922 796
            vis 100 C 20.7 22.6
            flashpoint F N.A. 460
            base number 10.8 N.A.
            oxidation (abs/cm) 8 N.A.
            nitration (abs/cm) 4 N.A.​
            Build Thread:
              bp, the leading supplier of high-performance lubricants has been selected as the engine oil partner for BMW. Learn more about the partnership here.
              Yep 2021
              Build Thread:
                I just ordered some Eurocar 10W60 on Autozone for $8/qt delivered. Honestly I've lost track over the years of all the variations: TWS, Supercar, Titanium...what's the difference nowadays with Castrol's offerings? Will my engine explode with one or the other(kidding)?
                  Its coming up at $12.99/qt. for me.
                    Its my understanding that the Euro Car is the only current 10W60 offering. I got it cheap at Autozone as well.
                    Old, not obsolete.
                      Same, until I put it into the cart and went to checkout and it applied a discount that got it down lower. This was a few months ago, so YMMV.
                      Old, not obsolete.
                        I did not know this. I thought the 10W60 was still a version of the Shell Helix.
                        Old, not obsolete.
                          It’s coming up at $12.99/qt. for me.
                          After I put it in the cart it was $7.99. And if you buy 5 (from autozone) you get a $15 rebate from Castrol. Two rebates are allowed per household as I understood the terms, so I ordered two cases of 6qt. So $35 delivered for 6qts. I couldn’t believe it. I figure it can’t hurt to have some extra if 0W8 and 16 are being rationed, the heavy stuff might be as well.
                            Thanks - that worked. 12 inbound.
                              Motul does a 10w60 which i'll be switching to.
