Starting the SMG to 6MT swap on my '04 M3, and I am curious what recommendations you all have about other maintenance tasks to take care of while I'm in there.
Car is 99% stock, CA/west coast car, 134,4XX on the odo.
Overall car looks like it has been maintained well, nearly every bolt/screw/etc looks factory. Everything works fine ATM.
Radiator was replaced at some point with a CSF unit, looks newer.
Service history is a bit checkered over the past few years, but the VANOS was done, and I am planning to do the subframe reinforcement either during the swap or later, not sure yet. Also still trying to figure out if the rod bearings were done.
I'm just thinking of what else I might tackle in the engine bay that would otherwise be hard to get to once intake manifold is back in.
IE starter maybe? various hoses.connectors? I am relatively new to the E46 world, I see CCV popping up as recommended sometimes too.
Apologies if there is an identical thread floating around with all the answers, I did not find a match in the search tool.
Thanks.
Thanks.
