So, long story hopefully made short. Recently purchased an '03 M3 that had factory navigation. PO removed navigation and added Eonon head unit. I have removed the Eonon, sourced working navigation head unit and installed. I also installed a Bluebus module for BT connectivity. Well, the navigation unit powered on and everything works EXCEPT the radio. The radio module does not even show up on the nav screen and thus all radio function buttons (i.e mode) do nothing.
Where to start? Is the Harmon Kardon radio module dead? If so, how to test (we check fuses). Is the subwoofer amplifier dead? If so, how to test. I was hoping to avoid being a parts replacer without knowing what is causing the issue.
Could my installation of the Bluebus be wrong and killing the Ibus signals? My next step would be to disconnect the Bluebus and reconnect the CD Changer and see what happens.
Are the small coax connections necessary? All are disconnect at the trunk modules.
TIA.
TIA.
