I have somewhat of a big issue I've run into. I had a big oil leak coming from my front crank seal - when I went to inspect and confirm I noticed my vibration dampener/crank hub bolts had backed out and were all finger loose. At this point I removed the dampener and saw the crank hub face was significantly scored with the alignment pin sheered off. Pics below for reference **
Now I am looking into replacing the crank hub itself and am wondering what all is involved in the job. I know timing will be the big concern so I will need to
1. Set the engine to TDC (using the cam timing tool and alignment dowl before removal)
2. Remove vanos and timing cover
3. Relieve tension from the timing chain marking and zip tying it to reestablish tension
4. Remove the small bolt on the sprocket and swapping it out with a new crank hub sprocket per this thread.
let me know if I'm forgetting anything crucial here or I have this completely wrong. I did not see anything in TIS or forum threads going into this as its a bit of an oddball job.
Another concern is the potential damage already done by this failure. Let me know what you all think, any help would be greatly appreciated
