Cold Start rattle, need a good ear please
  • jayjaya29
    Its probably leakage from your valve cover gasket that you are smelling.
    Plan on changing the upper timing chain guide while you're in there:
    S54 - Exhaust Upper Chain Guide Item # BS026For BMW engine S54 Product Information. Designed specifically for the BMW S54 engine, this exhaust upper chain.
  • 6speedS54
    Lama tells everybody their vanos seals are shot. <3 Lama though
    I don't think its loose header bolts, thats more of a sharp ticking noise.
    When/has the vanos ever been serviced?
    The reason I asked about the header bolts is I smell either exhaust or whatever it is at 5-8K when I step on it hard, so thought maybe a header gasket is not sealing well due to loose bolts
  • 6speedS54
    No clue 😆 I changed the solenoid, cleaned the valve body, and replaced seals on the sealing plate. I am planning on changing my valve cover gasket, and will service the VANOS at the same time. 130K miles.
  • jayjaya29
  • 6speedS54
    Lama at Beisan told me my VANOS seals are shot
  • 6speedS54
    started a topic Cold Start rattle, need a good ear please
    I recorded this audio yesterday morning. Last 10 seconds of the file is what interests me. I am not sure if this is VANOS, possibly loose header manifold bolts, loose timing chain? The noise goes away after a few seconds or if you give it slight gas. Would love to know if anyone heard this same noise. The attachment is a small m4a file.
